Projects Help with Guide headlight 682 repair
Discussion in 'Traditional Hot Rods' started by boutlaw, Oct 26, 2013.
  1. boutlaw
    boutlaw
    I could not find any threads regarding Guide headlight repair. I purchased a set that will require repair of marker light sockets. Has anyone repaired their marker light socket receptacles or installed new ones? Also, the marker light housings are different. I would like to purchase/trade for either housing to get a matched pair. Any help or reference to an existing thread appreciated.
  2. hooliganshotrods
    hooliganshotrods
  3. boutlaw
    boutlaw
    Thanks hooligan....just what I needed for repair of marker lights. The replacement marker housings they sell don't "tab-in" like originals so I'm still looking for a Guide replacement for either of the two types I have pictured.
  4. Kevin Lee
    Kevin Lee
    Super Moderator
    I'd think some careful work with a flap wheel could turn the left one into another right.
  5. adam401
    adam401
    Get another of the small earlier style. They are 100 times cooler. I always look for places that have big trucks/ equipment rotting away. Ive had good luck even recently buying Guides and parts. The side mount guides are drying up but still around if you look and are a great sourcs for parts. Good luck
    RICH B likes this.
  6. boutlaw
    boutlaw
    I thought about working over the smaller one to enlarge but actually like it better. Got a PM on a couple listed on eBay so may go that route. Never though about truck salvage yards and we have a couple here so I'll check that out too. If someone has a small window housing, I'm interested....
  7. Model A Vette
    Model A Vette
    You can remove the original sockets and install universal aftermarket ones.
    If you use the larger housings you can use sockets for 1157 bulbs to get turn signal AND running lights. You have to use the pointed lenses.
  8. Model A Vette
    Model A Vette
    Boutlaw-
    Here is a picture of my headlight with the larger housing and pointed lens.
    I'm not running the dual filament bulb but my friend, who gave me one of my headlights, is running the dual filament 1157 in his identical headlights.
  9. pecker head
    pecker head
    Anybody have any new contacts for Guide Headlight parts? I need retaining rings and outside trim rings , and the gaskets that go between the lights. Thanks Peck
  10. de-fenders
    de-fenders
    You may want to check with OTB Gear for outer rings and gaskets. They should have the retaining rings as well, but you could use those from any ‘70’s and back vehicles that used 7 inch headlight bulbs
    pecker head likes this.
  11. sloppy jalopies
    sloppy jalopies
    Those Guide bezels were used on '49-'59 Harleys ...
    I used to get them from "V Twin" bike parts for $27.00 each...
    careful buying retainer rings, they are 7" but are different thicknesses...
  12. pecker head
    pecker head
  13. wdglide
    wdglide
    I recently picked up OTB's trim rings. They look and fit fine.
  14. 325w
    325w
    Early Chevrolet some of their trim rings will work also.
  15. sloppy jalopies
    sloppy jalopies
    Makes sense, Guide was a GM company
  16. pprather
    pprather
