Help with Hubcap ID: Hollywood hubcaps?
Discussion in 'The Hokey Ass Message Board' started by 562roadster, Jan 13, 2013.
  1. 562roadster
    562roadster
    Hi everyone. I recently picked up this set of hubcaps. I thought they looked similar to the Hollywood flipper hubcaps. Anyway, they measure roughly 13.75" across. Would anyone know what these hubcaps are for?
    The last few pictures are the hubcaps on a 16" 40-48 ford wheel, for scale. I know they're not for these wheels but you get a better idea of the size of the hubcaps.
    Thanks,
    George
    kidcampbell71 likes this.
  2. Jonnie King
    Jonnie King
    from St. Louis
    Not totally sure, but these don't look like "repos". They could be factory-issue...but not sure of the make.
    PLUS, the "flippers" weren't "rounded"...they had to have a "flat spot", like Dodge Lancers or Olds Fiestas, to attach the flippers.
  3. 562roadster
    562roadster
    Cool. Thanks Jonnie.
    Anyone else with some more info?
  4. 562roadster
    562roadster
  5. Rikster
    Rikster
    I do not know who manufactured the hubcaps you got. They are nice wish more fine ribs than the regular single bar or moon hubcaps from the 1940's that we see most of the times. But there were several companies producing them, and some of them made more than one type.
    But the statement Jonnie made is not quite correct. The Flipper hubcaps do not have a flat spot. Basically its just a half moon hubcaps like you have with the ribs on the lower section. You could buy hubcaps like that for a smooth look. But those same hubcaps were also used with as flipper hubcaps, but then some holes were drilled in and the flipper was attached using those holes. But it was basically the same base as what you have.
  6. 562roadster
    562roadster
    Thanks for the info Rik! Much appreciated! I need to sell them, I'm just trying to get some info so I can price them correctly.
    Can't wait to get your book at GNRS.
  7. Jonnie King
    Jonnie King
    from St. Louis
    562roadster,
    Let me show you what I was talking about...Rik has valid info also, so he's not wrong.
    On the pix below:
    1. #1 Is a Lancer cap...like I have on my '57 Dodge Coronet D500. Notice that the center is sunken-in slightly to have a "flat spot" for the emblem to attach to. This is what I meant. This is the style I was explaining. (You can view mine on my '57 in the "Albums" Section of my Profile )
    2. #2 is an Olds Cap...same method. A slight "flat spot"/indent for the emblem to attach to.
    3. #3 is more of the style that Rik is explaining. And he's right. This style flipper IS curved along with the cap.
    So, there are varying styles, and each is cool !
    Good luck with those...they will probably clean-up a bit, and will look great for a new owner.
    Jonnie www.legends.thewwbc.net
    PS: Rik...wish I was able to get to the GNRS to meet up with you ! The book should be a winner !
  8. 562roadster
    562roadster
  9. alchemy
    alchemy
    Those are WIERD clips. Never seen any like that before. You can rule out wide-five Ford and '40 Ford. Maybe some Mopar wheel? Or off-brand?
    Other than that, those look like nice wheels. To help you price them, last year I sold a set of five Hollywood flippers that fit a wide-five Ford wheel, same patina, for $800. Since yours might not fit a popular wheel, they could be worth lots less, or lots MORE. ;)
  10. 562roadster
    562roadster
    I took some more pictures and did some more research. I looked at Rikster's site and found a set of Hollywood's that have the same clip. Now I need to know what they fit?
  11. Jonnie King
    Jonnie King
    from St. Louis
    562roadster...
    Here's a pic that rodncustom had on his thread that showed similar caps, with spinners, on this '39 Merc.
    Thought you'd like to see it:
  12. alchemy
    alchemy
    Here's a pic of what the backside looks like on a Hollywood cap for a wide five wheel:
  13. Rikster
    Rikster
    Different hubcap, the ribs are thicker on this more common hubcap than the one asked about.
  14. Mr.Musico
    Mr.Musico
    from SoCal
  15. 562roadster
    562roadster
  16. 5hrod3
    5hrod3
    They go on a 15 inch rim...50s ford Chevy....those clips go into the slots on the rim between the rim
  17. milo1303s
    milo1303s
    5 years ago that woulda been great info LOL
    X38 likes this.
