Customs Help with lowering roof but not "chopping the top"
Discussion in 'The Hokey Ass Message Board' started by Jeff13005, Aug 25, 2013.
  1. Jeff13005
    Jeff13005
    from wisconsin
    I would like to lower the roof without "chopping the top" I would like to keep it all done above the windows. I think the roof is to high but i dont like the traditional chopped top. Its hard to explain in writing what im thinking but I think a single cut around the top a few inches above the windows. Then drop the middle down 2 or 3 inches. Then fold over outside edge to fill in gap then weld and etc. Has anyone every heard of anything like this before? Can you point me in the direction of someone that has done this before? Ive spent hours and hours searching and can not find anything.
  2. 56don
    56don
    What car have you got? Are you talking about a high crown roof like a 54 Ford has?
  3. twenty gallons
    twenty gallons
    Welcome Don,
    try an introduction, works wonders
    Been there done that........
  4. Jeff13005
    Jeff13005
    from wisconsin
    Sorry I forgot that part. 1953 chevrolet 210. Yes like that
  5. gnichols
    gnichols
    from Tampa, FL
    ***uming you have an old Ford T / A closed car or truck of some kind...
    - Plan A for me is to raise the cowl / tank top and bottom of the windshield. I plan some sort of "high cowl" approach for my 29 coupe, raising the cowl about 3" so that the seam between the tank top and the cowl sides lines up with the bottom of the belt line under the doors. Who knows... film at eleven.
    - Plan B... if plan A's mockup just looks too strange, next I'll try eliminating most of the header piece over the windshield. You will still have the chop the top, but the windshield won't be any lower. Reduce the visor proportionately, or loose it entirely?
    Gary
  6. hattrick150
    hattrick150
    I know what you're talking about how about you give me a call at 6058684999.
  7. I have looked at the same on my 54, the crown is too high at the back from a time when men wore hats. We did a 50 like this and pulled a piecut from zero above the vent window to a couple inches around the rear of the roof. In this case it was tied into a chop but you could do it w/o the chop part.
  8. 2deuces64
    2deuces64
    I have seen a 54 Chevy wagon with this done and it looked good. Sorry no pix.
  9. Barn Find
    Barn Find
    from Missouri
    Sounds like a lot of work.
    Proportions are important. I used to think that several of my '50s and early 60s cars were too narrow. I would daydream about widening an entire car by 6 inches. I'm glad to say it never got past the daydreaming stage.
  10. Rusty O'Toole
    Rusty O'Toole
    There may be a simple way to do something like this if you like the vinyl top or Carson top look.
    Rebuild the top the way they used to do Carson tops in the fifties.
    1) Cut away the roof including rear window if you wish. You will need to get a new, smaller window from some other car, or make something up
    2) Build a new roof out of strips of steel in a basket weave pattern. It would go something like this.
    Start with a strip of steel 1/8 thick and 2" wide. Run it from the middle of the windshield to the trunk lid. Bend it, eyeball it from the side, until you get a pleasing contour. Weld it to the windshield header and the base of the back window.
    Add a couple of cross strips, also bent to a suitable contour.
    Continue long ways and cross ways until you have a grid about a foot apart or a little less. This is the skeleton of the roof.
    Cover with wire mesh, poultry wire which is fine mesh chicken wire.
    Cover the mesh with cotton padding like upholsterers use, and cover the cotton with muslin cloth. This gives the roof shape.
    Cover the roof with vinyl or canvas convertible top material.
    O ya before you put on the top material you will have to fit the rear window.
    Yes it would be a lot of work but it would give a real nice, custom appearance if done right.
  11. Torchie
    Torchie
    Yes people have taken the bubble out of the tops of cars before but I believe that it will involve more than just cutting around the perimiter of the roof and taking out a few inches then flattening down the exsisting edge above the doors and rewelding.
    I think that you will find that you will need to quarter the roof piece and move those pieces down and out to reattach to the cut above the windows. Then you will need filler pieces to make up the gap between the four pieces that you moved. Lots of welding with many chances of warping. But what the hell if you screw it up you can make a carson style top and call it good.
  12. Like I said, you can do it with a simple pie cut and some work around the rear window. Your main cuts are done a couple inches above the drip rail where it is easier to weld w/o warpage.
  13. Flatheadguy
    Flatheadguy
    Not sure if my memory is faulty or not. Back in the day we called it "pancaking" a roof. Just powering the top of the roof. Looks good on some, awful on others.
  14. dan31
    dan31
    Does anyone have pics of this?Its a interesting idea.If you "pancake "the roof the hood and trunk will need it too ?
  15. Rusty O'Toole
    Rusty O'Toole
    If you want an all steel roof the easy way is to use the roof off a newer car with a flatter profile. Cut the old roof off leaving a border of a few inches all around, then weld on another roof panel with a lower contour.
    Finding a roof with the right width, length and contour can be a challenge but it saves a lot of hand work. Pie cutting and piecing a roof together without warping it is practically impossible.
  16. mgtstumpy
    mgtstumpy
  17. 'Mo
    'Mo
  18. 56don
    56don
    Mmmm, someone mentioned pancakes??
  19. snaptwo
    snaptwo
    , George Poteet's '56 chevy post was done like that . Most tri-five chops don't look right , throws the proportions all out of whack. The pancake is not as extreme.
  20. 40FordGuy
    40FordGuy
    Pancaking it is,..... I believe it was done to a 54 Ford longroof, during one of those "Monster Garage" shows. If memory serves.....i think Gene Winfield was involved. The result looked good.
    4TTRUK
  21. Hotrodbuilderny
    Hotrodbuilderny
    I am pretty sure Sam Foose did that many years ago to a 40 Ford Sedan.
  22. Jeff13005
    Jeff13005
    from wisconsin
    Thanks for the help everyone it is very much appreciated!
  23. Ralphies54
    Ralphies54
    Did that when we chopped the top on my truck using the roof section of my prettywell used up 67 OldsCutl*** parts car and the inner cross brace from same.Pie cuts and dolly work and using the brace to reinforce and provide a place for dome lite and wiring and ended up losing 1.75 more inches along with the 5" chop.
  24. CharlieLed
    CharlieLed
    Mercury Charlie's 51 (Sweet Nadine) has a pancaked roof. Gary Howard did the chop and "de-doming" but I couldn't get much more info outta Charlie about the process. I'd like to do it to my Merc but I sure can't afford to take it to Gary Howard's.
