Help with major front end wobble!
Discussion in 'The Hokey Ass Message Board' started by salf100, Nov 28, 2012.
  1. salf100
    salf100
    Ok I have a 64 F100 2wd and have slowly been rebuilding the front end. Started with new king pins and what a difference! Then I put new bushings in the front springs and frame. Tires and brakes all new also. I greased everything up too.
    Problem is, when I hit a big bump the whole front end begins to shake violently. You can feel it in the steering wheel, column the whole cab. The shaking doesn't stop until I stop the truck. Then everything is ok again until another big bump. So what do yous guys think? Tie rods, drag link? Steering box is untouched and shocks need replacing to. I haven't had it aligned yet and was gonna wait till everything was done. Lastly, anyone recommend a good alignment shop in Sacramento area? Any help would be great. Thanks
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Shocks would be first on my list. Then if more than 2" free movement at the steering wheel rim either adjust,if possible,or repair the box.
  3. frosty49
    frosty49
    You can try a horizontal shock(steering stabalizer). This should take the wooble out. Also when you go to the alignment shop get your caster reading from them. It should be about 5 degrees or so. If not this could be your real problem.
  4. themoose
    themoose
    Do a search for "Wobble".There are a number of threads on the HAMB that will give you all kinds of good information on the subject.
  5. chopt top kid
    chopt top kid
    The dreaded "Death Wobble". Do a search and read for hours... Usually has to do with the harmonics in the rotating m*** of a straight axle front end. Just for grins, swap out the front wheels/tires for a test run and see if it goes away???
  6. salf100
    salf100
    Don't think the stabilizer would work. We are talking about scary, wheels gonna fall off wobble. Very violent! Im thinking snow ball effect with replacing worn parts as you go. The steering boxes arnt really adjustable on this truck. It will be the last thing I fix due to money issues. Id really like to keep the manual steering but use another box from something more plentiful. Parts for mine are NOS only replacements.
  7. TinShed
    TinShed
    All good advice but the steering stabilizer. That is a bandade at best, find and fix the issue. If nothing is loose get it aligned and report back.
  8. dorf
    dorf
    from ohio
    sounds like your steering box bolts are sheared at the frame. you can look all day and never tell it,but it is not unusal for the old fords.
  9. landseaandair
    landseaandair
    from phoenix
    Is it a new problem? Sure you got the U bolts on the springs tight?
  10. lanny haas
    lanny haas
    from Phoenix AZ
    I vote for a caster adjustment. Think of a shopping cart with a bad wheel
  11. Fenders
    Fenders
    " I haven't had it aligned yet and was gonna wait ........."
    It's alignment. most likely the toe. You can check that easily with a tape measure.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I had the same problem on my Willys coupe. At the right (wrong) speed it would nearly rip the wheel out of my hands.
    I fixed it completely by reducing the caster from 10 degrees to seven degrees - it could be even less but I ran out of adjustment - AND adding a steering damper from FieroParts.com.
    Many OEM applications with a straight axle use steering dampers, including my Cl*** A motorhome.
  13. salf100
    salf100
    How do I check with a tape measure? Ill get it aligned first.
  14. salf100
    salf100
    Well work and family has kept me busy, so no progress yet. But i am on my way to pick up my new tie rods, drag link and shocks! Now to find the time to install it all.....
  15. txturbo
    txturbo
    been there......seems pretty common on Ford trucks. Is this a straight axle or the twin I-beam? If its the twin I-beam type.....its the strut rod bushings and/or alignment(caster). If its a straight axle then its probably an alignment issue(caster).
  16. Tie rod ends or drag link or both, I don't recall if that front end has them but if it does idler arms will also cause that problem.
  17. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Replace/tighten up all that is loose and/or worn in the suspension and steering system, get it properly aligned and let us know if it still is a problem.
  18. alchemy
    alchemy
    Have you modified the truck at all? Even a change in tire sizes (more rake in front) will throw the caster off. You definitely need that alignment.
    You say the steering box is not adjustable, but you are wrong. The sector-to-worm is adjustable easily with the side bolt. If the worm bearings are worn, you can adjust with a change in gasket thickness on the end plate.
  19. bobbytnm
    bobbytnm
    Get it aligned. More than likely the "toe-in" measurement is out of whack.
    You can do set the toe at home. Do a search here or on google for tons of info on how to do it
    Bobby
  20. slingshotjimmy
    slingshotjimmy
    I had one do the same thing, after replacing all the steering parts,the steering box adjustment fixed it! Good luck! thats a scary problem!!!
  21. salf100
    salf100
    Thanks for all the i=tips so far guys. alchemy, I have always been told adjusting that bolt would cause more damage than good to an old box, but I will check it out.
    As far as rake, Its a tail dragger right now. I flipped the rear, but havent lowered the front yet. Keep in mind, this only started AFTER I installed the new front leaf bushings. I got my new tie rods, shocks and drag link yesterday. So as they go in, I will align her and keep you all posted.
  22. deto
    deto
    How are your tires? My friend had the same issue on his truck and after going through the entire front end it was worn out tires.
  23. deto
    deto
  24. tltony
    tltony
    from El Cajon
    The root cause is ac***ulated play from probably many sources. First, have someone rock the steering wheel back and forth while you lay under it and check every joint, shackle, box to frame etc for play. Adjust the steering box like someone here already said (worm gear 1st via shims and sector via side screw). Tighten wheel bearings set the toe at 1/8 in or so and grease it while it's jacked up. Too much caster like someone here said could contribute but it'd have to be pretty high to make it death wobble.
    I've done this stuff every day for 40 years.....And a steering dampner will help/fix it, but you're not addressing the cause of the problem.
    Tony
  25. salf100
    salf100
    So today my buddy and I worked on the front to my truck. Before we changed out any parts we checks the alignment and the toe was in 1/2"! We adjusted it to 1/8" toe and figured we give it a try. I drive it and no more wobble!! Who would have thought that slight adjustment would make such a difference. We then swapped out new tie rod ends shocks and drag link. Drives like a Cadi :)
    Thanks for everyone's input.
  26. bobbytnm
    bobbytnm
    Just as I suspected....lol
    Congrats on getting it fixed, now go out there and enjoy the ride
    Bobby
  27. "Fenders" called it first back in November in post 11. What does he win?
  28. salf100
    salf100
    Man it's been awesome driving it. What a difference since 2008 when I first got it. Now I just need to lower the front to match the rear. Amazing how well the steering box feels now that I've replaced everything. Rebuilding it should be pretty easy. It's been a mile stone too cause now everything under the cab is brand new from front to back.
  29. Don's Hot Rods
    Don's Hot Rods
    from florida
    Glad you found the problem and thanks for coming back and letting us know what it was. That is how we all learn. :D
    Don
  30. Unkl Ian
    Unkl Ian
    3/8" is not a "slight adjustment".
    Have it professionally aligned.
