Help with model A decklid handle- see pics
Discussion in 'The Hokey Ass Message Board' started by cubed, Dec 16, 2007.
  1. cubed
    cubed
    from Canada
    Is there supposed to be a pin here? The opposite side has one and there is a hole on the opposite side. Speedway (where I got it from) says no- but the br*** collar is really loose and sloppy......
    It is a vintique brand. Any body have one they could look at for me???
  2. Tindall
    Tindall
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Are you talking about the collar around the shaft up under the escutcheon(mounting plate)?
    If so, yes, the pin should have gone all the way through the shaft and out to support/retain the flanged collar correctly. This is probably a production error which the Chinese manufacturer is either unaware of (and Vintique as well) OR a deliberate way the Chinese have taken to save $.003 cents on the production of each and every handle to increase(?) profits.
    Call Vintique and see what they say.
  4. cubed
    cubed
    from Canada
    Here's the pics finally....
  5. synchro7
    synchro7
    I believe, if you put the key in and turn it that pin will move in or out. I think that pin is what locks the handle in the notches in the latch ***y.
  6. cubed
    cubed
    from Canada
    There is a square cut pin that you can't see in the pics that does that....
  7. synchro7
    synchro7
    Wasn't sure, I haven't looked at mine in about a year. I have a 30 coupe, full fender, top half of the hood, 32 shell and grill,64 289, 85 P/U OD 4-speed, 46 p/U rear end. I've had the thing for 36 years. Finally got it on the road last summer.
  8. DICK SPADARO
    DICK SPADARO
    I checked some handles in the shop and the pin that you are inquiring about goes thru to the other side. I think this pin is used in the cast handle portion to keep the square shaft from pulling out of the diecast part, if you overtighten the handle nut. The lack of the pin going thru should have no real bearing on the operation of the latch handle. Just don't tighten the nut up with a 1/2" breaker bar and socket.
