help with mopar dodge transmissions
Discussion in 'The Hokey Ass Message Board' started by Abner, Jun 16, 2010.
  1. Abner
    Abner
    I just got a 30 dodge, it has a 360 and a 727 in it now. I would like to run a manual transmission but i cant find any adapters. Does anyone know of a good manual trans to run with a 360?
  2. coolbreeze1340
    coolbreeze1340
    from Indiana
    Checkout "forabodiesonly.com" there is a great article about using a T-5 behind a smallblock dodge motor. Pretty easy swap, even easier on a rod.
  3. If you're looking for early pieces, be careful, the bell housings for 3 speeds and 4 speeds are not all the same. the 4 speed (A833) has a tall bolt pattern with one of the lower bolts offset, the 3 speed bolt pattern is almost square, IIRC.
    If you're shopping at swap meets, bell housings from the early "Poly" 318s will bolt up to your 360 as well. Big block housings look similar, but the starter is on the left side instead of the right.
  4. el Scotto
    el Scotto
    from Tracy, CA
    Wrong. It's in a different spot, but all starters are on the driver side, including the slant six.
  5. rjgideon
    rjgideon
    The A-833 would be the best option. It's a strong transmission and comes in different ratios, even in an overdrive from the F, M, and J body cars/miser trucks.
  6. Abomination
    Abomination
    Talk to this guy:
    http://www.jalopyjournal.com/forum/member.php?u=26736
    Actually get his number and call 'em. 5 minutes on the phone with Gary will set you straight as to what you need. :)
    ~Jason
