Greetings, I was looking for someone to help with a multi-carb set up in the Houston area. I am building a 392 hemi and it will run a 4x2 Cragar intake with 97s. My experience with multi-carb set ups is pretty limited so I wanted to employ some help from someone more experienced. I can build a fuel delivery system but will need help with setting up primary and secondary carbs and progressive linkage. I tried the famous***** at*****s Hot Rod Carbs but he is pretty backed up. Thanks in advance Yogi
1. are you running all 4 at the same time? (best with the big engine) 2. the carbs were initially on a small displacement engine and flow around 180 cfm's. 3. Have the carbs been rebuilt? 4. you can do it! 5. http://www.stromberg-97.com/tech_center/multiple_carb.asp
I run 4 carbs on my (avatar) 322 Buick engine, using the later 94's, I don't run progressive linkage, works great for me.
