Technical Help with old Truck Rear End Pumpkin
Discussion in 'The Hokey Ass Message Board' started by rustyironman, Jan 28, 2023.
  1. This old truck rear end pumpkin is in a very low production machine shop ***embled tractor from the late 1930's. I'm sure it was a common truck rear end pumpkin at the time.
    Can anybody give me some pointers as to the maker? I really have to get a diagram or service instructions on setting up the pinion bearings. I really would perfer not to learn how by tearing it apart.
  2. Mr48chev
  3. squirrel
  4. CDN FORD FAN
    CDN FORD FAN
  5. Provide a photo of the rest of the rear end to help us help you...
  6. gimpyshotrods
    gimpyshotrods
    I cannot put a make on it, but to my recollection, only a few brands had square tubes.
  7. seb fontana
    seb fontana
    from ct
    Timken Driving Axles is one I found with square tubes in the single reduction listing. Conversation me an e mail address I can send pics from motors truck repair, 16th edition. There is like couple hundred models.
  8. Boneyard51
    Boneyard51
    I think you may be overthinking it! It is a low speed tractor rear end and you are asking for pinion pre-load. If it is a shim adjustment set it up till no play and remove around .002. If it is the jamb nut style, tighten until no play, then a tad more! Over the years I have seen pinions that were “ loose” I mean you could actually feel play in the bearings with your hand in trucks and cars, and still functioning! It is best to set up proper, but it is amazing how far off it can be and still function just fine…..especially on a low speed tractor rear end! Just my opinion.
    Hnstray, VANDENPLAS, jaracer and 4 others like this.
  9. Budget36
    Budget36
    Was this something that was converted into a tractor?
  10. Beanscoot
    Beanscoot
    Yes, we like our *** pictures less tiny.
    Hnstray and alanp561 like this.
  11. jimmy six
    jimmy six
    I just tap on the little photos and then they get big…
    Hnstray and Boneyard51 like this.
