Hot Rods Help with reading plugs.
Discussion in 'The Hokey Ass Message Board' started by 68_F100, Jun 12, 2016.
  1. 19Eddy30
    19Eddy30
    from VA
    Just a Lost Art For On the Pump Gas!!
  2. lippy
    lippy
    from Ks
    I personally like NGK's. Notice the soot on the base of the plug? I wouldn't say the plugs are getting hot, usually will blister the porcelain a bit if dangerously lean. I would put a fresh set in and get some miles on it. Keep an eye on them during the next 1,000 mi. Get some miles on it before you p*** judgement looks pretty good right now, nothing wrong as long as you are not showing excessive heat in the plugs, give it a little time. Then fine tune. I am use to reading the cad plating burning off the NGK's showing heat tuning on alky or nitro. Hell I'm use to reading heat up into the first or second thread LOL. JMO Lippy
  3. 68_F100
    68_F100
    Here are some pics of the plugs after 200 miles. They still seem lean to me but I'm not sure. It's not running hot and doesn't ping.
    Not sure why 1 is darker than the rest
  4. 68_F100
    68_F100
    I went up two sizes in jets and I'm going to rumor a while longer and see how it looks.
  5. lippy
    lippy
    from Ks
    Tuning for the street is a bunch different than tuning for WOT. Your doing fine, you can fatten it up on the primary's till you see the reading you want may just take another fresh set to get there. I don't see a problem you will never have all 8 perfectly equal I don't think. Lippy
  6. Jimmy2car
    Jimmy2car
    from No. Cal
  7. models916
    models916
    No lead, alcohol in the fuel…impossible to get a reading without an A/F wideband meter.
