Help with SBC ID
Discussion in 'The Hokey Ass Message Board' started by draglink, Jan 24, 2010.
  1. draglink
    draglink
    from Tennessee
    I have been given a bare block. It was said to be a 327 ci. The casting is 3789817 and the date code is 62. The pad is T0827D. The only reference that I have indicates that this is a 327 block for 62-64 trucks or pass. cars. I do not have a mic but the bore appears to measure less than 4. Anyone have additional info on this casting? Could it be a 283?
  2. 30Abone
    30Abone
    this is from mortec.com
    3789817....283...62-64...2
    3789817....327...62-67...2
    it could be a 283 but there is nothing wrong with that.
  3. according to Moretc , that block was used on 283s and 327s...i had no idea that was possible. a 283 has a 3-7/8" bore , you should be able to get close enough with a ruler
    http://www.mortec.com/castnum.htm
  4. Suffix code D can be either a 58 or a 60 283 Neither of those line up with your date code. Something ain't right. http://www.nastyz28.com is a good place for decoding Chevy stuff
  5. squirrel
    D is the suffix for a 2bbl PG 283 in 1962.
  6. Thanks Jim. Nasty Z/28 website is usually pretty accurate but not 100% and that code didn't come up for 62 on there. That block should be able to take a .125 overbore if you wanted to use it to build a 327
  7. squirrel
    books, dude! :)
    Steffen Jobst likes this.
