Technical Help with step notch cad file
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Feb 5, 2026 at 11:43 AM.
  1. iwanaflattie
    iwanaflattie
    Hello hambers i need help with a step notch i have access to a cnc plasma cutter but im bad with computers.
    Does anyone have a file for a step notch for a 48 to 52 f2 or f3 ford truck or chevy?
    I only need about 4" of clearance..if I have to cut some off i can..
    Just seeing if anyone can share something i can use, itll save me a bunch of time.
    I can pay if needed.
    Thanks in advance
  2. K13
    K13
    Do the people with the plasma cutter not have someone who can program CAD? A step notch should be super basic for someone with experience. Just take them some basic measurements or even a cardboard cut out of what you want and they should be able to program it in short order.
    lothiandon1940 likes this.
  3. FrozenMerc
    FrozenMerc
    Do you have a napkin sketch or image of what you want replicated?
  4. iwanaflattie
    iwanaflattie
    Its my welding teacher..I really dont want to take more of his time,hes already helping me weld some aluminum and set and cut with the plasma.
    Ill draw something when i get home.
    Thanks for the replies.
  5. NoelC
    NoelC
    What we don't need to do then is improve your computer skills, we need to remind you that in the traditional method they used pencil and paper to communicate. Believe you me it still works. However, if you discover the computer is a tool to be used, you discover all kinds of stuff to learn from.
    Yeah, I'm going to disagree. While most of them do, and anyone can (even I have a cad program) , that doesn't make you experienced enough to do more then muddle thru it being my experience. That "short order" is all about the application of knowledge and common sense in using the tools one has. After all, he has to turn on the computer, log in, open the program, open a file, decide if you need a template or going to free hand it offering information into the computer. How many fingers they type with... Most say an hour for that magic of file generation just because it cover the guy taking the order and the walk to deliver it. And we all know what that hour is worth, lots.
    Sounds like you need to visit the librarian. Not only to improve your computer skills, but to discover they most likely have those programs available to learn with.
  6. K13
    K13
    No one who has any proficiency in CAD is taking an hour to program a step notch. All the nonsense of turning on the computer and logging in etc all has to be done to run the plasma cutter so adds nothing to the time already required.
  7. alchemy
    alchemy
    I am very proficient in CAD (cardboard aided design). Can’t you use scissors and a sharpie to do the design, then an angle iron straightedge and a torch to do the cutting?
    lothiandon1940, Moriarity and NoelC like this.
  8. iwanaflattie
    iwanaflattie
  9. deuce1932
    deuce1932
    from Australia
    19Eddy30 and Damon777 like this.
  10. NoelC
    NoelC
    StamCo, 780-436-2647 give them a call. Argue with them. GT Metals, 780 434-8721. Compare. Fact is unless you have a CAD file on disc in the format they require for their system to communicate, it's going to cost you. They maybe have one from a previous customer on file, or because the guy on the drafting side is aware of what's being asked, but still, drafting time spent is money being spent. And no, the guy who draws isn't often the guy on the tools. But let us know what you find out?
    That right there is a reason for my saying, I admire you taking good advice and with it posting a picture, but you could have spent a bit more time executing on the art work before doing so. Come on. You telling me that's the sketch you want to hand in?
    You want to remember a few thing about drawing and one that I missed doing this was darkening my object. Adding a ***le block and some additional detail on material maybe. I used the lines as a scale, folder for a ruler and a pencil.
    https://welderseries.com/tech/installing-a-rear-step-notch-kit/
    And save yourself and that overworked teacher the work.
  11. RodStRace
    RodStRace
    There is a thread in theOT section with Project Truck in the ***le.
    He just did a step notch on his truck. @guthriesmith is the member.
    I doubt his CAD file will be perfect for your use sincew there are a number of different programs, but should give you a better idea of what to design.
  12. iwanaflattie
    iwanaflattie
    You are the MAN!!!! Thank you.
  13. K13
    K13
    This has nothing to do with what a business would charge to do the work. You said it would take an hour and it certainly wouldn't which has clearly been shown by the fact that it took far less than that for a member here to get a notification that measurements had been posted, come here and get those measurements, create a CAD file, zip it and attach it here. Instead of always trying to be a know it all on here maybe you should actually read what people write rather than just blather on about things that have no relevance to what is being talked about.
    9200 IH likes this.
