Hot Rods Help with Traditional '30 Model A Coupe build
Discussion in 'The Hokey Ass Message Board' started by TiredIronGRB, Oct 19, 2010.
  1. TiredIronGRB
    TiredIronGRB
    I think it looks much better with just the shift-gate...
    BTW, the shift knob isn't staying...it's just so I don't impale myself.
  2. 35mastr
    35mastr
    from Norcal
    Updates are looking good.
  3. 63dan63
    63dan63
    Looking good. I suggest you find your deck lid B4 you try to align the rear qtrs. They are all unique. jmo
    Dan
  4. TiredIronGRB
    TiredIronGRB
    Yes, I have one and have started aligning the rear body...it was a mess, I think it had been used as a truck.
  5. Mr.Musico
    Mr.Musico
    from SoCal
    good thread, looks like your having fun with it..good read
  6. hellsgaterods
    hellsgaterods
    flathead and ****** would be great look and a trophy getter, but not if you want to go fast. friend of mine has that setup, wins at car shows but gets left behind cruising. steering column should be useable too.
  7. TiredIronGRB
    TiredIronGRB
    Pulled my engine from the donor and will start cleaning it up and changing out the intake soon. It looks pretty nasty but it's a good running '62 283 PowerPack. I will use the ramhorns, generator and plug wire holders.
    Made a stand for the seat which hinges in the front, decent storage compartment.
  8. deto
    deto
    Congratulations. You have mastered the HAMB in mere minutes. That is not a joke.
  9. TiredIronGRB
    TiredIronGRB
    Framed up the trunk area and made some body/shock mounts.
    Used the framing to square up the rear cross-member, them aligned the fenders.
    Body/shock mounts are 1.250" X .250 wall.
    Cheated a little and got a RCI 15 gallon fuel cell, safety first.
    Trunk fits decent.
  10. lorodz
    lorodz
    looks real good
  11. BBYBMR
    BBYBMR
    Lookin' good - real good!
  12. TiredIronGRB
    TiredIronGRB
    Rolled the coupe outside for the first time, hopefully the next time it goes out will be under it's own power.
    Modified a '40 Ford pedal to fit.
    Used a stainless piano hinge and a set of M37 (Military Dodge truck) windshield stays to mount the deck lid.
  13. TiredIronGRB
    TiredIronGRB
    Worked on my carb linkage, I had to rework it some to clear the banjo fittings.
    Worked some more on the gas pedal, I think it will work out pretty good.
    I made the cowl top removable to ease working on the brakes and electrics, I used these latches to hold it in place and will tack some short screws in the original mounting holes.
  14. Looking real good, man you work fast. I must have missed it, but what size tires are you running...same size front and back?
  15. TiredIronGRB
    TiredIronGRB
    16X6 all around but I may trade them on a "big and little" set up.
  16. TiredIronGRB
    TiredIronGRB
    I got the gauge holes cut tonight, filled some holes in the firewall and fabbed up a battery box.
  17. qzjrd5
    qzjrd5
    from Troy, MI
    Great progress man - keep it up!
  18. Ford Mike
    Ford Mike
    Like the idea for the cowl, nice car!
  19. lorodz
    lorodz
    keep at it ...
  20. sambo
    sambo
    I don't know, from here it looks like you don't need any help!
  21. TiredIronGRB
    TiredIronGRB
  22. boutlaw
    boutlaw
    Wow, love the cowl holddown clamp idea. I wanted to do something similar, but was not smart enough to figure it out, so now, I am stealing your idea. Where did you get those clamps? Is that a Lowes/Home Depot piece? Glad i subscribed and am following your progress...keep the text and photos coming.
    Outlaw
  23. TiredIronGRB
    TiredIronGRB
    The hold down clamp is a Destaco model 381 DE-STA-CO J hook, I got them on eBay. I beefed up the lid where the "J hook" clamps and will post some pictures latter tonight.
  24. TiredIronGRB
    TiredIronGRB
    This is where the "J" clamp hooks to the cowl top...
    Got the last of the throttle linkage finished.
    Made some framing for the rear fender wells, going with a 3" notch for the spring.
  25. HomemadeHardtop57
    HomemadeHardtop57
    slick idea with the cowl latches
  26. Krash
    Krash
    from Cleveland
    Looking good. You work real fast. I dig the headlight/shock mounts and the cowl latches. A fine job.
  27. TiredIronGRB
    TiredIronGRB
    Since I don't plan on running a hood I'm trying to mount as much of the electrics as I can out of the weather.
    Now that all the electrical pieces are in place I'll start building the wiring harness.
  28. crashbox
    crashbox
    Get Vern Tardel's book. You've got the right mix of Ford stuff for a great start. Forget about the S10, that's bunk.
  29. TiredIronGRB
    TiredIronGRB
    Dude, read up :rolleyes:
