Projects help! z bar in the way of headers
Discussion in 'The Hokey Ass Message Board' started by Brodbeckh, Nov 17, 2022.
  1. Brodbeckh
    Brodbeckh
    A month ago i got new headers for my 250 chevy in a c10 not much info i was given about the headers themselves except that they are hedman and the may have been for a camaro. i attempted to put them on but they so close before the collector end hits the z bar what should i do? ive heard people heating up and moving the arm, shaving, or outright cutting and welding it farther away. this is in a 1964 c10 whatever is the path of least resistance tell me
  2. saltflats
    saltflats
    from Missouri
    Modify the header or get one that fits that would be the easiest.
    1Nimrod, Jibs, alanp561 and 5 others like this.
  3. 6sally6
    6sally6
    Easiest...?!!! What saltflats sez.
    Does it hit the actual bar or the arm hang from the bar?
    Dead center or just barely hits it?
    Can ya reposition the Z-bar bracket that goes to the frame? Moving it back just a little...
    Picture is worth a...........(you get the point)!
    6sally6
    1Nimrod, alanp561 and deathrowdave like this.
  4. alchemy
    alchemy
    Make it a U bar?
    vtx1800 likes this.
  5. Wanderlust
    Wanderlust
    Cable or hydraulic are options as well
    1Nimrod and bobss396 like this.
  6. gimpyshotrods
    gimpyshotrods
    May we please have a picture, or two?
  7. Nailhead Jason
    Nailhead Jason
    need pictures of the linkage and header installed
    1Nimrod likes this.
  8. 1971BB427
    1971BB427
    from Oregon
    Considering modifying the Z bar has the potential to change ratios or leverage to the pedal, it's the last thing I'd change. I'd go for either a correct header for the C10, or modifying tubes on this header if you just have to use it.
    As mentioned, pictures of what you've got will help.
    1Nimrod and X38 like this.
  9. jimmy six
    jimmy six
    Dent the header. Friberger proved it doesn’t make any difference.
    1Nimrod, Jibs, Stan Back and 5 others like this.
  10. Brodbeckh
    Brodbeckh
    Please explain
  11. Brodbeckh
    Brodbeckh
    Atm not the bar
  12. bobss396
    bobss396
    I went hydraulic with my car, it was the easiest solution at the time.
    1Nimrod and sdluck like this.
  13. Brodbeckh
    Brodbeckh
    Where can I find cable driven clutch kits
  14. Brodbeckh
    Brodbeckh
    Anyways I’m making a new thread for this on a clutch cable swap kit
    1Nimrod likes this.
  15. gimpyshotrods
    gimpyshotrods
    So no pictures?
    1Nimrod likes this.
  16. Brodbeckh
    Brodbeckh
    Outta state atm
  17. alchemy
    alchemy
    I'm guessing the header wants to go right through the center of the Z? Make the bar go up and over, or under, the header. Keep the pivots in the same place, but cut the middle out and make it go around.
  18. Stan Back
    Stan Back
    Whatsa Zbar?
    WalkerMD likes this.
  19. squirrel
    that's what a Z bar is.
  20. gimpyshotrods
    gimpyshotrods
    It also sometimes called a clutch equalizer bar.
    1Nimrod likes this.
  21. gimpyshotrods
    gimpyshotrods
    He as a 250 L6, so the choices may be limited.
    1Nimrod likes this.
  22. squirrel
    oops! I thought I saw 350 in one of the other threads....
    I'll wait for the pictures along with every one else.
    1Nimrod likes this.
  23. 41rodderz
    41rodderz
    from Oregon
    Get the headers for a truck . P***enger car headers are of course different. I have a set of new old stock with stickers still on them . You may or not be as lucky. You also can fab your own set or modified as stated. I haven’t decided if I am going the way of headers, split manifold or stock . Good luck.
    1Nimrod likes this.
  24. gimpyshotrods
    gimpyshotrods
    $273.99
    https://www.summitracing.com/parts/hed-69310/make/chevrolet/model/c10-pickup/year/1964
    X38, NoelC, 427 sleeper and 1 other person like this.
  25. SASROD
    SASROD
  26. Jokester
    Jokester
    Time for a 700-R4?
    .bjb
