Technical Help!
Discussion in 'The Hokey Ass Message Board' started by Pontiac life, Feb 26, 2018.
  1. Pontiac life
    Pontiac life
    Can someone help me identify what these valve covers were off of?
    Here's what I know: They fit small block Chevy's and they look the same as the Chevrolet script valve covers (minus the script)
    Thank you!!
  2. upspirate
    upspirate
    Small Block Chevy
    wvenfield and XxMikexX like this.
  3. Speed Gems
    Speed Gems
    Canadian Pontiac?
  4. Pontiac life
    Pontiac life
    Yes, they are definitely SBC, but what year or model?
  5. Pontiac life
    Pontiac life
    hmmm, maybe?
    Funny cause I'm building a Pontiac with a SBC and that's why I want to use as valve covers ;-)
  6. Squablow
    Squablow
    Are they staggered bolt pattern? It's hard to tell from the pics. The lack of breather holes makes me think they're early, they might have been from a Pontiac built in Canada (they used 265/283 Chevy engines) or marine use.
  7. Pontiac life
    Pontiac life
    I believe they are GM # 3970298
  8. Rusty O'Toole
    Rusty O'Toole
    They must have been made after Chevrolet changed to even spaced bolts in 1959 and before they put oil fillers and PCV valves in the late sixties. GM of Canada made blank valve covers so they could put Chevrolet or Pontiac stickers on them.
    Later... camera angles can be tricky but they look like evenly spaced bolts to me?
    pitman and Speed Gems like this.
  9. Pontiac life
    Pontiac life
    Yes, they look early............hadn't thought about Marine use?
  10. Pontiac life
    Pontiac life
    And they are not staggered bolts
  11. Pontiac life
    Pontiac life
    I think you might be right!
    Hot Rod Nut and Speed Gems like this.
  12. 46stude
    46stude
    Or maybe '65-'66 Studebaker Thunderbolt 283.
    Which were Chevy 283s.
    Speed Gems likes this.
  13. timwhit
    timwhit
    I recently sold a NOS set of those covers. They were orange and had Tonawonda decals on them. I always thought them to be truck covers, one of the decals mentioned trucks. Of course, you can decorate then to be whatever you want, probably reall fun thing to do.
  14. Or maybe Checker taxi cab car.
  15. buick bill
    buick bill
    from yreka;ca
    I had a six in a Pontiac with stock 250 66 I think, six and no name . now have a 64 gmc was 230 stock no name . all still chevy !
  16. Speed Gems
    Speed Gems
    Yep, some of those had Chevys in them to.
    Genes12320 likes this.
  17. We got Pontiacs in the early 60's here with 283's, with the same valve covers. All made in Canadia.
  18. DDDenny
  19. donno
    donno
    Damned if I don't learn something new every day!!
    ratfinkhotrod and Hot Rod Nut like this.
  20. DDDenny
    I see that both of your covers have the temp sender wire retention clips (spot welded).
    As far as I know the production engines only had those on one cover. I do recall reading that the non tabbed cover (by part number) was discontinued and replacements all had the clips.
  21. Pontiac life
    Pontiac life
  22. Pontiac life
    Pontiac life
    Same here!!
  23. choptop40
    choptop40
    Old internal pvc covers...
  24. King ford
    King ford
    from 08302
    If I put a rodent engine in anything I sure wouldn't want a name on it !
    Genes12320, loudbang and Speed Gems like this.
  25. Pontiac life
    Pontiac life
    hahaha.........thats why they made the blank covers!
  26. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    So are they both drivers side???
  27. Pontiac life
    Pontiac life
    No, driver side has clips p***enger doesn't.
