Help!!!!!!
Discussion in 'The Hokey Ass Message Board' started by topcop5129, Sep 18, 2011.
  1. topcop5129
    topcop5129
    from niles Il
    I've got a huge proble with turn signals on a 1959 Impala. I replaced the switch and bought the rebuild kit from eklers thats installed in the column. The problem was this..... The turn signals were working fine. Then they stopped. What would happen is, you would use the signal, it would blink maybe 5 or 6 times then stop? I thought maybe it was the dash light acting funny but it stopped blinking outside also? So I install these new parts and it's still doing the same thing? Sometimes it will even blink when its in the off postion? The wiring is all stock and in excellent shape????? It's driving me CRAZY!!!!! PLEASE HELP.
    Edited by Ryan... With a note: Glad to help, but you should probably be respectful to the membership when asking for it.
  2. 54 Chevy
    54 Chevy
    Have you replaced the flasher. Maybe causing a short.
  3. Scotts Enterprises
    Scotts Enterprises
  4. badshifter
    badshifter
    Looked at all your past posts. Didn't see a single person be an ***hole to you. I saw you didn't do an intro, and were asked to do it. You posted an OT car and were told it was an OT car. Posted pictures of your car painted in a weird/odd two-tone and were given feedback you didn't like, and then agreed with. You've asked lots of questions and were always given friendly help. You seem to be a bit thin skinned. Gotta be less sensitive on a forum.
    Anyhow, sounds like you have a bad flasher. But the info you provided is a little incomplete so that's just a stab in the dark. Keep at it, you'll like it here.
  5. THE_DUDE
    THE_DUDE
    Grounds are a killer on Impalas. Replace your flasher.
  6. shinysideup
    shinysideup
    from ruskin, fl
    Bust out your voltmeter and trace down your problem.
  7. topcop5129
    topcop5129
    from niles Il
    I did give an into, Also it wasn't on the board it was private messages that were sent to me. No worries!
  8. topcop5129
    topcop5129
    from niles Il
    where is the flasher on the car? Fusebox?
  9. wetatt4u
    wetatt4u
    You say you "HAVE'' a HOTROD shop
    but you DON'T know where the flasher unit is on a car ?
    Are you serious or are you pulling our collective legs, as in just kidding !
    I just looked at your public profile page and tried to check out your Shop for ****s and grins
    ,but I didn't see anything on it....
    What gives,just wondering...
    If you look under the dash beside/or on the fuse block you'll find the flasher unit,
    its about one inch round and has flasher printed on the side...
    Good luck.....
  10. topcop5129
    topcop5129
    from niles Il
  11. THE_DUDE
    THE_DUDE
    Round job in the fuse box. When you replace it check for rust in there.
  12. also the t/s switch is on the top of the column down close to the floor. it is moved by a small rod from the arm and is adjustable. most of the time if it still blinks with the arm in the neutral position then the switch is out of adjustment or gummed up.
