Projects Helping an old(er) couple out
Discussion in 'The Hokey Ass Message Board' started by The_Cat_Of_Ages, Jun 26, 2023.
  1. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Pull the spark plugs and squirt some Marvel Mystery Oil in the cylinders and let it set for a few days before you attempt to crank the engine. Check the ignition for obvious problems and maybe install some new points and condenser and clean or new spark plugs. Buy a can of ether for initial start up. Maybe one of those cheap spark testers so you know its getting spark. Then worry about getting fuel to it.............after you know it will crank and spark.
  2. RodStRace
    RodStRace
  3. fortunately this is not my first rodeo, i used atf/acetone on my '57 before starting it and it was cheaper than marvel and worked perfectly.
    i plan on using a dish soap bottle full of gas instead of ether, cheaper and i have them lying around instead of going out and buying them
    chryslerfan55 and ekimneirbo like this.
  4. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Just saying that the first trip over there may be wasted if you don't plan ahead a little. Its a PITA when you just need one little thing that you didn't plan on and the whole day gets wasted because you have to chase a part down or the engine just won't turn over................:D I like the ether for that very first spark ignition because it always fires with a spark, where as I have flooded engines that were cranking slowly when trying to use gas. Its personal preference for me just to eliminate one more chance of me screwing up.:)
  5. luckily since its a ford i can just jump the solenoid and it should turn over
  6. They went on vacation with their family, so im still waiting for them to be ready for me to be out there working. still hoping to help them out, my "free time" this summer will be coming to a close.
    chryslerfan55, X-cpe and Okie Pete like this.
  7. Put a 50's 235 Chevy Carburator on it, the O/G Ford Carbs are N/G. And add dual exhausts.
  8. I would if i was hot rodding it, its a long bed step side truck. plus its not my call.
  9. Bigmac48
    Bigmac48
    from Dundalk Md
  10. Bigmac48
    Bigmac48
    from Dundalk Md
    Fortification.com is a good site with lots of info on all ford trucks from F1 , bump sides dent sides , etc , lots of forums to check out + diagrams , schematics. . And great job for making there dream come true !
  11. jimmy six
    jimmy six
    Then ….Your old too…..80
    The_Cat_Of_Ages and Dick Stevens like this.
  12. ouch...
  13. JohnLewis
    JohnLewis
    Anything new? Quite enjoy your threads, did time run out on this one.
  14. Im still waiting on them to be ready but im kind of out of time. school starts tomorrow.
    itll be over the weekends sometime. i really do want to help them.
  15. nosford
    nosford
    I was wondering if anyone was going to get to the "problem" that caused the truck to be parked in the first place. Thanks Marty, saved me the trouble!
  16. Atwater Mike
    Atwater Mike
    Younger brother's '50 Merc got a '39 Ford ****** because of this problem. (short ****** required a 5-foot+ driveshaft)
    ****** mainshaft was '50 Ford pickup, with the rear housing/slip joint....
  17. would a long tail housing t85 work? that would shorten the driveshaft up
  18. Budget36
    Budget36
    Change the ***le of the thread to “older” ;)
  19. better? :D
    Budget36 likes this.
  20. Budget36
    Budget36
    My man!!!!
