Hot Rods hemi 354 exhaust guides
Discussion in 'The Hokey Ass Message Board' started by truck 1946, Apr 16, 2013.
  1. truck 1946
    truck 1946
    Hi everyone
    can anyone give me some advice on hemi 354 exhaust guide valves.
    The original guides have a hole in the guide close to the head as per original specs. I am putting in replacement hothemiheads guides that do not have this hole. Isn't it necessary and if not, are valve stem seals required as the originals didn't run any ?
    Thanks for your help
  2. 73RR
    73RR
    The hole was/is there to allow a very small amount of lube to the stem.
    If you choose to not drill the new guide then set the clearance a bit loose.
    Exhaust do not normally use seals.
