ForSale: Hemi Hotrod Hobby Kit! $12,000 What you get: 1929 Ford Model A Coupe body with 4" chop, decently replaced subrails and poorly done patch panels (very salvageable) 1929 Ford Model A stock rolling ch***is with clear VIN number (missing one frame horn but I will throw in a replacement) 1940-ish Ford Steelies with old STA tires. 1955 Chrysler Hemi, rebuilt with Isky 270 Mega Cam, Gear Drive intake, 6 fresh Holley 94's (two set up as dummies, but only need jets and power valves to run them), linkage, fuel block, regulator, etc. ($400 worth of stuff from ****ster27), Hurst mounts, NOS Transdap (I think) transmission adapter and NOS Schiefer (I think) aluminum flywheel, and clutch Muncie M20 (I think, I can't remember if it's an M20, M21, or M22, but I do remember that it's NOT close ratio or a "Rock Crusher") 4speed transmission Hurst shifter with linkage I purchased the motor rebuilt, but I have not fired it. It looks BRAND NEW under the valve covers, and you can hear the compression when you turn it over. I have all front accessories, not pictured, including a brand new alternator. Clutch/Flywheel/Trans adapter appear to be NOS. Transmission shifts and spins, but should be considered a core. Body is off the frame and "as-pictured" with the exception of the fuel tank which is now only the top piece (tank portion cut out), with a separate upper firewall piece included. My plans were to set the motor back into the cowl. I expect to take several more photos for any interested party. Rolling ch***is components are all stock Model A and in rebuildable condition. Wheels are NOT the ones pictured. I have other hotrod parts that can be purchased separately to finish your build (rear ends, juice brakes, steering boxes, dropped axles, etc). My plans were to build a crazy, low, slingshot style car with the engine setback under the cowl, big slicks and motorcycle wheel fronts, etc. Something kinda like Deaths Door. I'm asking $12,000 which is nearly what the motor/trans is worth. This project is NOT a roller. It's located in Northern California, but I'm willing to ship world wide. Will be sold with Bill of Sale ONLY! I can get a ***le for an extra $1000, but would require a deposit up front to start the DMV process (because I'd have to basically build the car into a rolling mockup). I can ***emble the car into a rolling ch***is for shipping purposes for an additional fee. ***Flathead and Red Wheels/Whitewall Tires NOT Included!!***
