Technical hemi cams
Discussion in 'Traditional Hot Rods' started by carryallman, Jan 5, 2014.
  1. carryallman
    carryallman
    im building a 392 hemi,need a camshaft-what would you recommend ?? its a 060 overbore ,cast pistons -10-1,probably use a set of "hot heads aluminum heads" single4 barrel hh alum. imtake ,magneto w-hei internals in an anglia on the street ,with a 5 speed trans,kinda confused on what to use ? hyd. solid ,roller ,lift duration whos lifters to use ?did read some articles about china lifters ! need some info right away ,need to get something ordered this week ! kinda thought id try -bob walkers stuff -hot heads ? had some problem w/comp cams -soft cam cores awhile back -still no refund {460 ford stuff }thanks guys
  2. TERPU
    TERPU
    Call Isky, they will set you straight.
    All the best,
    Tim
  3. powrshftr
    powrshftr
    Engle also specializes in early Hemi cams,and their tech guy is really prompt about returning emails.
    Scott
  4. I have a Comp Cams 235/235 @ .050 in a stick car and its not that radical. Will probably go up to a bigger cam soon. (edit) not that radical to me anyway. It does have some lope.
  5. ago
    ago
    from pgh. pa.
    Hydraulic would be easiest to maintain, adjusting valves on an early
    Hemi W/adjustable pushrods is not easy. You might want to a search on here about the magneto HEI, lot of problems with the unit.
    Ago
  6. dodge59
    dodge59
  7. What's your compression, rear gear and tire diamter? Then what is the power ban you are experiencing?
