HEMI DEUCE WATERPUMP Fit Probs
Discussion in 'The Hokey Ass Message Board' started by marfen, Feb 5, 2014.
  1. marfen
    marfen
    from sask
    32 ford, '56 Chrysler 354 Hemi with truck heads , BBC waterpump , Walker rad. No way a bottom hose is going on now. I know you guys have sorted this out but I can't find anything in hemi tech threads so any solutions are much appreciated. I'm thinking maybe shortening the w/p inlet some. thanks
  2. ago
    ago
    from pgh. pa.
    I took SS U-bends and welded up a tight radius and used short pieces of rad hose. You don't need stainless.
    Ago
  3. Pete Eastwood
    Pete Eastwood
    from california
    Try a '55-'57 chevy V8 lower hose
  4. 73RR
    73RR
    By the looks of it, ago has the solution.
  5. I used a 7996 Napa (21285 Gates) with a 903 Napa adapter.
    Be sure to get a hose with a spring inside to prevent the hose from collapsing.
  6. marfen
    marfen
    from sask
    Cool, thank you all.
  7. ago
    ago
    from pgh. pa.
    A photo of my 354 Hemi in my 32 Ford
    Ago
  8. marfen
    marfen
    from sask
    looks pretty much the same as mine...and you got it to work! cool
  9. ago
    ago
    from pgh. pa.
    Make sure you have a bead or lip on the SS pipe so the hose doesn't blow off. I have 14000 miles on my setup, no problems.
    Ago
  10. marfen
    marfen
    from sask
    Thanks for the pointers. It kinda looks like my lower waterpump hose fitting is on the long side (Weiand w/p) which makes finding a hose tougher since it has to hike back in and forward.
  11. It's all these pesky details that drive you bat **** crazy, take forever, and keep you off the road.
  12. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I bend up some tig wire to the shape I want cut to length center m*** from pump to radiator....... ask the part store to look at all the hoses...go to the back and have spent up to an hour looking thru them all.........usually find a section of something that will work.........just make sure you measure both diameter ends you need..........Dave
  13. oldolds
    oldolds
    Copper pipe and elbows, silver solder, short pieces of straight rubber hose.
  14. SimonSez
    SimonSez
    I have a BBC in my '32 which has the same issue, and ended up making up a steel pipe up to the one that Ago did.
    My engine is very close to the radiator so I used donuts to get nice tight bends and then had it HPC coated in a black teflon finish which has held up ok so far.
    A friend of mine also has a BBC powered '32 and he modified his aluminum water pump and was able to use a simple off the shelf 90 degree rubber hose.
    He cut the lower water pump tube off at an angle, flipped it over and then TIG welded it back on (it is an water pump).
    This means it is pointing down more than out and gets around the issue of the hose having to come back in before it makes the turn to the radiator.
  15. Chuck R
    Chuck R
    Sorry it's so dirty, but this combo has worked for 45,000 miles. After seeing this picture it's clear I need to give her a little love.
    chuck
