hemi extended bellhousing vs. short
Discussion in 'The Hokey Ass Message Board' started by SixFour, Feb 7, 2011.
  1. SixFour
    SixFour
    from So cal
    besides the bellhousing, what makes the short bellhousing hemi, pretty sure the years are from 51 to 53, more desireable? I know the 54-55 have the better heads. Any info will help
    Thanks
  2. RichFox
    RichFox
    The later Chrysler has a tin timing chain cover that is nicer looking than the iron early cover. Cam snout is different as well as the oil filter mount and pressure relief. The later stuff is eaiser to get aftermarket.
  3. George
    George
    Put Hemi Tech Index in search & start reading!:)
  4. George
    George
    Small cover didn't start untill '55, & then only on cars. Cam snout didn't change untill '56, & Oil filters are the same.
  5. RichFox
    RichFox
    Not true on the oil and filter housing. My early long bell housing 331 had the byp*** built into th filter housing and a extra port in the mounting face on the block for byp*** oil to return. My later Windsor 331 and 392 blocks had only 2 (Oil in and oil out) Pressure relief was internal. Tin cover may be true and the same for cam snouts. My Dodge engines picked up on the newer style sooner than that.
  6. George
    George
    Some early 331s don't have the check valve between the upper & lower p***ages in the block, block wasn't drilled for them, don't know if all or some.
  7. More adapters/options for transmissions.
  8. George
    George
    rereading..this is backward! the short tails are 54 & up, long tail are 51-53. The short tails are easy to adapt to A/T, besides the better heads.
  9. 73RR
    73RR
    Beauty is in the eye of the beholder...
    The 51-53 engine does not have any advantages over the 'normal' 54-58 engine(s). The 51-53, even with small ports and valves, can make respectable power, but not as much, perhaps, as the 54 with the same monetary investment.
    The biggest disadvantage, is the trouble adapting an auto trans. If you plan on a manual then it is not so bad, in fact, if you have access to machine tools you can make your own!
    Make damn sure that you have the bottom bellhousing piece!!!
  10. vegas
    vegas
    This was true on my '53...^
    I used a long bellhouse adapted to a T5, and it worked out for my coupe. I bought a whole car to get the engine, and got that bottom bellhouse piece! ;) The original transmission/torque convertor/clutch with a flexplate and flywheel is a strange site! Glad I could get rid of all that with some help from Wilcap!
  11. SixFour
    SixFour
    from So cal
    Thanks everyone for all the info. So besides the ****** adapters, if I bolt on a pair of 54-55 they should make the power and have the same potential??
  12. RichFox
    RichFox
    They run just as good in my experiance.
  13. George
    George
    Checked the Hemi Tech Index yet?
  14. SixFour
    SixFour
    from So cal
    Yeah I've been reading the index, I can't really find a solid answer is why I'm asking.
  15. George
    George
    the 54-6 heads have bigger ports, the 55-6 heads have bigger ports & valves.
  16. 73RR
    73RR
    Swapping later heads onto an early block needs to be done cautiously since there is a coolant p***age that does not line up...:cool:
    Unless you are really in need of 350+ hp I say use the early heads. Spend the money on forged pistons, good cam and rebuilt rocker arms.
    If you have excess money then buy a 392 and be done with it...
  17. SixFour
    SixFour
    from So cal
    cool, and thanks for all the info i appreciate it
  18. moparmonkey
    moparmonkey
    from NorCal
    Not to sidetrack the post, but what exactly has to be done to get the later 54-55 heads on an early 331 block?
    I've got a couple of early 331 blocks, and a couple sets of later heads...
  19. George
    George
    '54 gasket's the same. Think '55 gaskets on '55 heads will work, Dowel change & other changes like less tall '56head will cause leaks with '51-4 gaskets.can co
  20. 73RR
    73RR
    Compare/overlay early and 'later' gaskets and you will quickly find the coolant hole problem and how neither gasket really does a good job of sealing the other. The proper 'fix' will be to plug either the block or the heads and redrill to match the gasket.
    Dowel pins pull out of the block, put in new ones.
  21. moparmonkey
    moparmonkey
    from NorCal
    Thanks! :D
    Do you have a preference as to which p***age you block, or does it matter?
