Hemi Heads
Discussion in 'Off Topic Hot Rods & Customs' started by johnfin, Dec 17, 2025.
  1. johnfin
    johnfin
    from Florida
    Subaru refuses to call their heads, Hemi heads. They call them boxer heads. Dont they look like Hemi heads?
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the off topic forum
  3. 57 Fargo
    57 Fargo
    No they don’t, true Hemi heads don’t have a squish/quench area
    SS327 and Moriarity like this.
  4. johnfin
    johnfin
    from Florida
    I guess that and it 4 valve. I dont think mopar made a 4 valve hemi,
    SS327 likes this.
  5. ottersea
    ottersea
    Hemi heads are hemispherical, these are not
    SS327 likes this.
  6. They are pent roof like most 4 valve heads.
    SS327, Eric David Bru and 57 Fargo like this.
  7. Bandit Billy
    Bandit Billy
    Ahhh, there is nothing like a HEMI head...and that is nothing like a HEMI head.
  8. twenty8
    twenty8
    Well, that was a waste of time. Lucky it's only a short thread about nothing......o_O
    Ned Ludd likes this.
  9. Ned Ludd
    Ned Ludd
    Well, there might be an educational tangent or two?
    "Pentroof" is an approximation: it's usually closer to a round-hipped thatch roof. The point is that the circles of the two intake valve heads are in the same plane, and likewise those of the exhaust valve heads, suggesting the two slopes of a pitched roof. Therefore none of the valve stem axes p*** through the cylinder axis. Therefore the circles don't describe a common part-sphere.
    Abarth called their take on the hemi head the Testa Radiale, i.e. both valve stems were on radii of the part-sphere which formed the combustion chamber. If I remember correctly they did develop a 4-valve version of this, with all the valve stem axes radial and none parallel as in a by-now-cl***ic pentroof, also based on the same Fiat pushrod architecture.
    The Subaru head has pairs of valves with their stem axes parallel and their heads in the same plane. There is no way to develop a single part-sphere from that, so not strictly a hemispherical combustion chamber.
    While we're doing tangents, a lot of guff gets spouted about the thermal efficiency of a hemispherical combustion chamber. A full-spherical combustion chamber would have the smallest surface area for its volume, which is desirable: but on an engine of square dimensions that would imply a compression ratio of precisely 1.5:1. That is hardly practical. Making the piston crown flat rather than hemispherically concave does improve that a bit, at the cost of a good deal of thermal efficiency. To get to anything like a decent compression ratio would involve domed piston crowns, leading to a combustion chamber shaped like half an orange peel, which is really extremely thermally inefficient, worse than any humdrum bathtub or wedge shape. It does afford the opportunity to get very big valves in, though, big enough to make it worthwhile if you're after power rather than efficiency as such.
    SR100, twenty8 and RMR&C like this.
  10. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I have ***umed(I could be very wrong) that the angles of the intake valve stem and the angle of the exhaust valve stem formed a TRUE 90degree angle which is one of the features of a true HEMI. This is the main reason the late model HEMI that the Mopar people make is not a true HEMI is because it doesn’t meet the true definition of a HEMI.They can only claim a “partial” HEMI,or a semiHEMI, not a true HEMI!! Do the above statements appear to be TRUE??? Thanks to all HAMB MEMBERS WHO RESPOND!!! 8138286689658629012.jpeg
    Deuces likes this.
  11. gene-koning
    gene-koning
    Why would Subaru want to identify their motor with a name a different car company has identified their performance motors with for many years?
    Would that name not mean to many people that the Subaru motor would then be identified as being copied from the Chrysler design, even though Chrysler was not the first company to use the Hemi head design? Chrysler merely copied the head design, then advertised it as their performance motor for years, pretty much claiming it as their performance motor.
    SS327 likes this.
