Hemi help...
Discussion in 'The Hokey Ass Message Board' started by Ruiner, Apr 4, 2006.
  1. Ruiner
    Ruiner
    I was wondering if any of you guys had any links to Hemi related websites? I've already looked at hothemiheads.com and was trying to find other sites like that relating to hemi parts, troubleshooting, and whatnot...
  2. Bass
    Bass
    from Dallas, TX
    You're already on one of the best.
    Ask whatever questions you have and sit back and learn.
  3. maud
    maud
    from Maud,Tx
  4. Soviet
    Soviet
    There were lotsa hemis made - what exactly are you looking for
  5. Ruiner
    Ruiner
    Specifically I only have a 331 and a 354, but I might get my hands on a couple others down the road, one being a 330 Desoto...but I'm interested mostly in sites dealing with NOS, new and repro parts such as trans adapters, oil pumps, rebuild kits and so on...I know allpar.com has the history and background, and I guess troubleshooting can be taken care of here when the time comes...
  6. Soviet
    Soviet
    Ive been chasing parts for my 331 for a year now. Ill post up all my links that I have at home later today, if none else beats me to it. Carefull with those hemis man, theyre addicting, and drain your bank account like no other. Do you have any pics of your pair?
  7. Ruiner
    Ruiner
    My digital camera took a dump on me a month or so ago, so no pics...and I hear ya on draining the bank account since I just started looking for other motors lately and have come across about 4 motors locally, each for under $350 bucks...in the next 2 months it's quite possible I could have two 331's, a 354 and a 330...the last two still run, and both 331's are "stuck" which I've dealt with before on many different occasions with other motors, mostly B/RB mopars...
  8. Gotzy
    Gotzy
  9. Ruiner
    Ruiner
    Oh, see...that's exactly why I asked this "stupid" question...I forgot all about Egge...thanks, I'll go check em out right now...
  10. Andy
    Andy
    PAW has adapters and also parts for the Chryslers. The 330 will be the most expensive and difficult to get parts for.
  11. Just Gary
    Just Gary
    I've been gathering bits for my '58 truck 354. Hot Heads and PAW probably have the most (and biggest variety) of parts. Here are some more:
    http://www.roadsters.com/hemi/#Sites
  12. Ruiner
    Ruiner
    Ok, now here's another stupid question...I have a line on an industrial 354...are these internally the same except for cam and possibly crank/rods? What would it take to get one of these to stock/slightly modified specs of the same year production hemi?
  13. George
    George
  14. scootermcrad
    scootermcrad
  15. Ruiner
    Ruiner
    ****, for 13 bucks including shipping, consider it bought...but I'm still curious about the 354 industrial engine, is it worth picking up for 300 bucks even if it sits around for a year or two before I have a use for swapping the internals? I know the valvetrain is adjustable on the Industrials, since the valve covers have bumps in them to accomodate this, but I just want to make sure it can be converted before buying a $300 paperweight for the garage...
  16. Andy
    Andy
    My knowledge is from the Dodge industrials. They have p***. castings but small valves. The exhaust will probably be sodium filled and have 7/16 stems. Some new valves ,seats,and guides will fix. The rockers are probably not adjustable. They changed the tooling and all got bumped covers from then on. I would get it.
  17. MoePower
    MoePower
    from Omro, WI
    Hell yea, for $300 snag it up and yes I'm almost positive you can convert one.
  18. Ruiner
    Ruiner
    I'm just taking a shot in the dark here, but is that Mopar Dave I see?...
  19. HotRodChassis
    HotRodChassis
    Alliance Vendor
  20. scootermcrad
    scootermcrad
    Yes! Get it! I heard that not all Industrial motors have the adjustable rockers even if they have the "bumped" covers. Keep that in mind. The adjustable rockers trains would be nice to have. If you don't want it, tell me where it is and I'll go pick it up! :D
    That book will cover the major differences in that Industrial motor. The biggy is how the water flows I think. I'm sure someone can elaborate on that. I don't remember what I read. I think there is something with the camshaft end also.
  21. Soviet
    Soviet
  22. George
    George
    You need to change the cam to an automotive one. You can change to car heads 354/'55 331 will work fine!
  23. Ruiner
    Ruiner
    I won't mind having it sit around the shop until I can find some car heads...I'll pick em both up then if the guy still has em...so that would bring my count up to a 331, 354 and a 354 industrial...not bad I guess...
  24. hemispherical
    hemispherical
    from indiana
  25. scootermcrad
    scootermcrad
    I think the Industrial heads can be used... Jimmy White runs them on his 331. I think you just have to do some simple modifications... it's covered in that book I beleive. Maybe someone can tell you what needs to be done to the heads.
  26. George
    George
    Are the heads solid on ends or have water openings & does intake have/ not have thermostat housing? See if crossover that goes under the carb is square or tall & narrow. Square is same as auto. If intake has thermostat housing & you want to use it, you can use the '54 oval exhaust port heads.
  27. Ruiner
    Ruiner
    I haven't picked up the Industrial one yet...but when I do, I'll be picking up a p***enger car 354 with it, so it'll just be a matter of seeing the differences in them side by side...with any luck I might be able to pick them up on the 13th, but my wallet might say no...I'll be picking up my 331 that morning for $325, then I'd have to drive an hour and a half back home, unload it and drive 3 hours north to get those 354's for $300 each, then drive 3 hours back home and unload them...that's a minimum of 12 hours of driving and loading/unloading...plus it's $925 bucks out of my pocket not including gas money...if I had a full-size truck I could do it all in one shot...damned Ranger...
  28. Ruiner
    Ruiner
    Ok, so I called yesterday to try and schedule a time to go pick up those 354's...and today I get a reply e-mail saying they're both gone...now I'm sure the guy doesn't know I'm the one who sent the original e-mail AND called about them...I just hope to (insert deity here) that they are both still there and that the mix-up between the e-mail and phone call mean that by calling he considers them gone...but worst case scenario he has a 331 w/****** for sale too, so if they are sold then I'll pick that up...and if I do get the 354's and the 331 and ****** are still there I'll give you guys a heads up as to how to get ahold of him and pick it up...
  29. Ruiner
    Ruiner
    So it's official, the two 354's went to someone in Wisconsin, and by the time I called to say I'd take the 331 w/****** he said someone is coming to pick that up on monday...the only hope being that if the guy doesn't show up with cash in hand then I'm next in line...the good news is I'm still picking up the original 331 next Thursday, so at least I have SOMETHING to put into the '40 g***er...just wish I had more so I had parts and a backup plan should one motor fail or not be usable...I'll just have to keep my eyes peeled for another one down the road...
