Hemi Help.
Discussion in 'The Hokey Ass Message Board' started by Buick59, Jun 7, 2004.
  1. Buick59
    Buick59
    from in a house
    I just picked up a 38 Lasalle transmission that I wanna use with my 331 Hemi. Any websites or places that sell adaptors and bellhousings? Also…I use to (but lost it) had an article on how to adapt chevy 350 motor mounts to a Hemi. Anybody got any info on this either?
    Thanks.
    Mike
  2. Andy
    Andy
    The motor mounts was in a Street Rodder artical about a year or so ago. I had made a plates with holes tapped for the chevy mounts and welded ears onto it to match the hemi mounts. If you want I can post pics. because I never installed the engine.
    I made a chevy to cad adapter for a guy. You might get a hemi to chevy adapter and make a new adapter plate to go to the cad.
  3. Otto
    Otto
    Andy, what issue was the article in? I am interested in this info as well. Can you post those pictures?
    Have you checked Wilcap for the ****** adapter?
  4. The37Kid
    The37Kid
    Triva question: Which block is wider, Chrysler HEMI or SBC?
  5. Fraz
    Fraz
    from Dixon, MO
    I know the heads on a hemi are what make them so dang wide, so I venture to say the SBC block is wider.
  6. Buick59
    Buick59
    from in a house
    Andy posting those pictures would be cool. It would help. Which issue of Street rodder was it in?
    Mike
  7. Andy
    Andy
    Batterys are dead in camera. Going out later and will pick some up and post. Don't know what issue artical was in. My son gets the mag and I saw it at his house. I had done mine a few months previously.The mounts will be wider than chevy because the mounting ears on the chrysler stick out. Won't line up anyway because the chryslers are so far forward.
  8. Andy
    Andy
    Picture of mount. I made a 3/8 plate to fit the chevy mount and then drilled and tapped to match.Ears welded on to match Chrysler.
  9. Andy
    Andy
    View from back.
  10. Buick59
    Buick59
    from in a house
    Andy thanks for taking the time to post the pictures. Now if someone can point me in the direction of Bellhousing'sand Adaptors for the Lasalle ******.
  11. Andy
    Andy
    I offer a picture of the adapter plate I made for a friend that has a 350 in a 40 LaSalle. If you could find a hemi to chevy adapter and find or make something like this you would be set. They were avail. in the '60 for $20 or so.
  12. Ham
    Ham
    Mike, you finally gonna get that thing running? R U going to Tony's shindig in Idaho?
  13. Buick59
    Buick59
    from in a house
    Yeah I had one of Bo's fab men start building a frame for it last weekend. I have maged to find some good swap meet parts. Now it's time to start gluing all the pieces of the roadster.
    There is this guy in So Utah that sells Lasalle adaptors for the long block Hemi.He has none for the short block. Of all the **** luck!
    I can't believe nobody else has leads on them! Maybe I should turn this into an off topic post about magazines or something.
    Thanks again to Andy for the info. I reckon I'll just have to have something made up.
    Mike
  14. bulletproof1
    bulletproof1
    from tulsa okla
    i set a 440 beside my 331 and the motor mounts look the same ,im going to try and use them ,just make the lower part that bolts or welds to the frame
  15. Just Gary
    Just Gary
    the37kid,
    When the engines' exhaust manifolds are installed, the SBC is ~1" wider. It's because the Hemi exhaust ports point down, while the SBC exhaust ports point out horizontally.
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Mike, check out Capanna's stuff.(adapters and such).go to roadsters.com and look under hemi links....they will make anything and possibly have a n.o.s item in stock
    good luck
