Technical Hemi hydraulic lifter clarification
Discussion in 'The Hokey Ass Message Board' started by ruben solis, Jul 30, 2024.
  1. ruben solis
    ruben solis
    Their was a conversation started back in early 2024 by 73RR & RodStRace concerning Hydraulic lifters issues. I purchased a set of lifters from Egge machine p/n ELGHL-1812 which are supposed a direct replacement. I also talked with hot heads and they said the same. anyone with any suggestion the lifters are still rattling and are soft. Also this is my first 1955( 270 baby hemi )Build. I have asked the adjustment of the adjustable push rods, I here 0-lash then 1/4 turn ?. Are these lifters correct.
  2. 73RR
    73RR
    The part number would seem correct; ELGin HL 1 812
    In an otherwise stock ***embly with adjustable pushrods you will need 2 full turns to achieve approximate 0.048" preload and then go another ½ turn to get to 0.060.
    If you only go ¼ turn then your preload is about 0.006. All of this is based on the pushrod having 24tpi.
    dwollam likes this.
