Hemi ID
Discussion in 'The Hokey Ass Message Board' started by Mike Landwehr, Jul 7, 2006.
  1. finally got out there and looked it over REAL good -NO stampings that I can find ,took a pic of the area I thought it would be ahead of the valley pan ,windsheild has 1953 331 written on it, BUT the short bell and sq water p***age crossover suggest to me its something else what ya think ?, I think i made a deal on it this morning.
  2. lucky_1974
    lucky_1974
    Look infront of the valley pan there will be numbers first numbers tell you the year. That should help.
  3. If it says chrysler industrial and those are the original valve covers it can only be a 331 or 354.
  4. Kerry
    Kerry
    Is there a plate down where the bell bolts on behind the drivers side hood? Most industrials have ID there. If I remember IND56 is a 331 and IND56A is a 354.
  5. the one pics shows no stamping #'s ahead of the vally pan, Have to look for that plate if its there. I am wanting a 354, not a 331, so I have to nail this old pig down ;D,Other HAMB'rs know of this truck/motor and are interested, so if its not what I want I'm p***ing it on to them.the only reason I am interested at all is because this is a low milage rebuilt ,if I had to rebuild it I'd p*** on it FAST:eek:
  6. ground_pounder
    ground_pounder
    its got the water crossover on the front of the head, if that matters
  7. ground_pounder
    ground_pounder
    you gonna finally take this one on mike?...it needs to be in your garage...
  8. Andy
    Andy
    I would think that is a 54 331. Not a 354 for sure.
  9. My Chrysler book says 51-52 Hemis have the number on the left side of the block below the head, between the first and second cylinders. Maybe it's an early one?
  10. George
    George
    The heads are no earlier than '55, before that there were no water outlets @ front of heads. There should be a casting # between the head & valley pan on p***. side rear, if tab in front of vally pan is blank.
  11. pistinbroke
    pistinbroke
    I've got an old industrial beside the garage and it also has no stamping numbers in front of the valley pan, it has a plate rivited (sp) to the block near the bell housing. Is it original to the truck? Or is it someones old (rebuilt) farm equipment bolted into the truck? I ask because some of those Industrials had a cam that will not work past 2800 rpm. This ofcourse is because they were made to run all day at the same speed. Easy to fix that though.
  12. 4tford
    4tford
    With the motor mounts cast in the block it is newer than '53. especially without an extended housing.
  13. its definately not orig. but I will know more when i find that # :D
  14. bulletproof1
    bulletproof1
    from tulsa okla
    i have a 53 industrail 331 with cast in motor mounts& a short bell housing! mine is stamped in front of the valley pan and has the Id plate on the bell housing.
  15. bulletproof1
    bulletproof1
    from tulsa okla
    looks like its not an industrail motor,it has the same timing cover as my car motor .the industrials have a case cover and a extra water port in the block
  16. BobbyD
    BobbyD
    from Belmont NC
  17. Kerry
    Kerry
    I've got a pair of industrial 354's and both have the tin timing cover you say they don't have. Yes, they were original. The style of front cover is often, but not always, more an indicator of vintage on the Chryslers.
  18. Ruiner
    Ruiner
    there are so many variations of the industrial motors over the years, and it's also quite possible since it's been rebuilt that they put later model heads on...honestly I think it's a variation of the 331 industrial with 354 car heads, I can say with a pretty good certainty those are not industrial heads since they don't have the cast in accessory pads on the front for mounting various governors and other junk that was needed for industrial motors...I'm sure they swapped timing covers along with the heads if the block turns out to be an industrial...I dunno...if it's not stamped in front of the valley pan then chances are it is an industrial, so find that ID tag and we can all sleep better...
  19. scootermcrad
    scootermcrad
    I was thinking maybe it was just a 354 with industrial valve covers. Is that a possibility? Just thinking.
  20. ol fueler
    ol fueler
    Even if it turns out to be a 331, its a simple matter to bore it to a 354 , beside it's only 23 inch difference. If it is an industrial motor it will probably be low compression & have a cam that will need changed. New pistons & a cam is nowhere near as costly as a rebuild. If its a good deal ---Grab it !!
  21. going out there tomorrow flashlight in hand, Tuck thinks he may go as well
  22. revkev6
    revkev6
    from ma
    dunno hemi's very well but I would question the work done to it. who put the fan on backwards.....
  23. scootermcrad
    scootermcrad
    If you can, pull one of the valve covers and see if has adjustable rockers... that is if it doesn't have numbers. Check out the bellhousing also. I don't think any 331's, including Industrial motors had water outlets at the front of the heads. Numbers will tell you everything though... if you can find them.
    Good luck and keep us posted!
  24. heh heh saw that did ya? i wondered how long it would take someone to say somthing about that, It was his son just to keep it w the motor :rolleyes: ,we'll get the number's tomorrow or Wed.
  25. revkev6
    revkev6
    from ma
    I was thinking more along the lines of a reverse rotation motor. Special use for that 1 forward/3 reverse gear transmission he had lying around.....;)
  26. Ruiner
    Ruiner
    not all industrials had adjustable rockers either...and I still think those are p***enger car heads...it would be interesting to see what the block turns out to be...I'm surprised at how many people didn't read the original post and keep mentioning rebuilding it or the cost of doing so, it's already rebuilt, so chances are it doesn't have the industrial cam in it...my guess is the guy had a p***enger car motor laying around with a bad block, swapped cam and heads, threw in some rings and gaskets and called it a day...hurry up mike, I didn't sleep worth a damn this afternoon...hahaha
  27. krooser
    krooser
    All three of my IND's have late-style blocks...no extra water outlets...the books are WRONG....
  28. hemifan
    hemifan
    Looks like a dedicated INDUSTRIAL motor in it's original format. I've the same as pulled from a military water pump rig. Mine is a 331 by measurement with 354 p***enger car heads (no sodium filled valves!). It came with the stamped timing cover and p***enger car style water pump. The pump shaft is a bit oversized like the car units used on air conditioned cars. It had a governor controlled 2 bbl and log type exhaust manifolds dumping out both ends. Rockers were hydraulic. Pistons were flat top only with low compression. The cam was the late short snout and suitable for a re-grind. The block casting # is indistinct on the very digit that differentiates the 331 from the 354 castings. I've not had it sonic checked but suspect it's a 354 block which was never finished to size. Can anyone confirm this? Such thick cylinder walls would be great for a blown application.
  29. got the code -alum plate on Blhsng says it all- took a pic + I looked at it here under my photo enlargement program IND-56 which makes it a 331 IND,BUT I think it would work in a car as it has P*** heads and water crossover if I am understanding this right I can't have it too broke so it is up for grabs for anyone else $1200 FIRM to HIS SON, not my deal or Pauls
  30. George
    George
    The usual comment is to change cam/lifters if you think they are the originals.
