Hemi in a Traditional Deuce??
Discussion in 'The Hokey Ass Message Board' started by jhl1963, Dec 24, 2009.
  1. jhl1963
    jhl1963
    from ny
    Hi guys, torn between a traditional car with a flathead and some big horsepower. I came across this pic and thought it was interesting. Can anyone tell me what engine this is (392??) and what's involved with putting a Hemi in a 32? Need to lengthen the ch***is?
    http://clarkehotrods.com/wp-content/uploads/2009/06/100_3092.jpg
    Thanks guys.
  2. kwoodyh
    kwoodyh
    welcome to hamb ville! You already have a deuce and the hemi or flatty or just dreaming out loud? ;)
  3. jhl1963
    jhl1963
    from ny
    Thanks kwoodyh - got a ***le and a dream :) I'd like to start with and engine and go from there.
  4. kwoodyh
    kwoodyh
    wow! I prefer the Ford in a Ford route myself! Either way is cool it is all a matter of parts you can find or already have and motivation to make them all work together! good luck brother!
  5. LSGUN
    LSGUN
    from TX
  6. jj mack
    jj mack
    331, 354, 392, it is really hard to tell the differences in Hemis by a picture alone.
    Please search...lots of good info on here.
  7. It can be done. Just move the center of the firewall 1 3/4" on the drivers side and 3/4" on the other side. 354 Hemi. with a Chev water pump saves a couple of inches.
    HemiDeuce.
  8. or a remote waterpump tucked out of sight ....
  9. MengesTwinCustoms
    MengesTwinCustoms
    Huge horsepower probably wouldn't be necessary and a flathead ford in a car that came with one is way cooler and it bolts right up!
  10. WhiteZombie
    WhiteZombie
    from Denton TX
    Whats not traditional about an early hemi in a deuce?
  11. jhl1963
    jhl1963
    from ny
    Thanks fellas - HemiD/4T beautiful cars/installs.
  12. lippy
    lippy
    from Ks
    Or you could ditch the water pump and water and put it on alky injected.:p:D
  13. HEMI32
    HEMI32
    Stupid idea! :rolleyes: :D
  14. claymore
    claymore
    Hemi all the way.
  15. skwurl
    skwurl
  16. I guess it depends on which traditional you are shooting at. If you are looking at period correct bfore the 50s and valve in head engines then a flatty is the only way to go. But of the period you prefer is after over head valves became popular then a Hemi one option a**** many.
    It takes a lot of suspension to hold one up and you may have to hammer your firewall to get it in there.
  17. Bullet Nose
    Bullet Nose
    My friend had a BBC water pump on his Hemi .....
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Do IT!!!! HEMIFIED!
  19. 66Coronet440
    66Coronet440
    As cool as flatheads are, there is just something about a Hemi in those cars...
  20. Either engine is way cool in my mind . . . kind of depends on the look you want, the $$$ you want to spend, etc.. The Hemi is a lot harder as far as fit and fabrication is concerned - they are big *******s and they make everything harder to setup (headers/exhaust, steering, clutch/brake, motor mounts, etc)..
    You can save a LOT of weight on an early Hemi if you go the aluminum head route (Hot Heads), aluminum water pump, etc.. They'll end up weighing about the same as a small block Chevy if you go this route.
    As I've been heavily involved in both engine types, I'll stick my neck out and say the Hemi will typically cost more -- if you want the "go fast" goodies that many like --> four 97 carb manifold, adjustable rockers, cool valve covers, etc.. But - you'll have 2 - 3 times the horsepower and some would say an early Hemi is an easier engine to keep running well than a flathead . . . personally I think it's a wash in this deparment.
    Take time to really read on this site, look up all the posts you can about early Hemi's in early cars, PM some of the members who've actually done the work, etc.. There is plenty to learn - might as well do it before you start spending too much money and get over committed one way or the other.
    Either way - you'll have a great car . . . just a personal choice and a pocketbook in the end!
  21. With a full hood...............a '54 331 with '55 354 heads.
  22. farmer12
    farmer12
    Hemi all the way,no doubt!
  23. holeshot
    holeshot
    from Waxahachie
    1963...HEMIs in coupes is traditional my man, and if you have a torch, mig, and experence anything is possible. but if you lack just 1 of these! then brother your in deep DO-DO...POP.
