Hemi in Model A coupe.
Discussion in 'The Hokey Ass Message Board' started by olskl_dave, Mar 25, 2012.
  1. olskl_dave
    olskl_dave
    My coupe just arrived from the US.
    l'm looking for info from anyone , l want to stuff my Hemi in it, but mine has the extended block.
    has anyone got picks to show how much space l'm going to have let inside the cab? l have a Toploader and a th350 to choose from.
    Any help would be greatly appreciated.
    Regards Dave.
  2. luckyuhaul
    luckyuhaul
    No advise, but WOW! That car is beautiful!
    You're hanging br***, that's for sure!
    Good luck and have fun!
  3. Stovebolt
    Stovebolt
    The manual would be better, as the T350 will extend back too far.
    You might also consider a C4, as it has a detacable bellhousing.
    Whats happening with the original running gear?
  4. olskl_dave
    olskl_dave
    Thanks.
    l'm not sure yet , l've got another frame so i might just roll this one out and rod the other one. Maybe keep it for a 4banga roadster pickup project.;);)
    Regardds Dave.
  5. LabRat
    LabRat
  6. olskl_dave
    olskl_dave
  7. Stovebolt
    Stovebolt
    Wilcap makes adapters for your block.
    Someone out here makes the hemi/C4 adapter. Might it be the Fountains?
  8. Great looking 'A' Dave. Toploader trans, I say. But you'll have to do some home work. Rodders have been making odd things fit together for years.
    CM
  9. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Awesome!!!!!! fresh meat!
  10. jtille
    jtille
    Nice.....Going to keep my eye on this one!!!
  11. Nice Coupe. Great car to start with, will be a great combo..
    Manual I'm thinking.
  12. Noland
    Noland
    wow thats one clean coupe. Your going to have to do some serious reinforcing to that frame to handle the weight of the hemi. Thats one of the reasons I chose a 32 frame but I believe you could use Model A frame as far as width goes maybe definetly cant use stock location of steering box because started and head make it a very tight spot even on my 32 frame. I beleive your going to have some problems with firewall clearance though also your hood if intending to run one will have to have "bubbles" put in it to clear the heads. As far as an automactic goes the only one Ive seen fit to a extended bell hemi is a Touqueflite that they cut the bell off of. But theres a few chooses for standard shift. I used a Hot Heads adapter to use a GM standard Trans because I liked how it had a provision for a throw out fork. Good Luck with your build
  13. dv8
    dv8
  14. LabRat
    LabRat
    From what I've read you will need to turn the firewall around and a short water pump and pulleys and possibly a (choke) elect. thermo fan .
    Look forward to your progress ...:cool:
  15. olskl_dave
    olskl_dave
    Thanks for all the support
    Regards Dave.
  16. Nice coupe, To work out the inside cab creature comforts and sizes just make up a bit of a cardboard mock up that you think will cover the rear of the engine and gearbox,
  17. moparmonkey
    moparmonkey
    from NorCal
  18. Loudpedal's Green Grenade has/has the extended bell hemi.
    Man thats a nice car, its going to be a beautiful hot rod.
  19. tfeverfred
    tfeverfred
    No advice, but DAMN there's a group of restorers forming a lynch mob!:eek::D Good luck with it. It's always a treat to see a Hemi put in a rod.
  20. st.rod
    st.rod
    Oh my god what a beautiful car. It would be a shame to hot rod it!
    Just kiddin' chop that *****, box the frame and make it fit,
    Larry
  21. 1938ute
    1938ute
    from australia
    Nice score dave
  22. roseboystoys
    roseboystoys
    Here's ours! Has a GM 200 4R with Lightning rod shifters....you're probably better off with a 4 speed since you're limited on space. It's pretty tight with the Automatic.
  23. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Hemi + model a= watching!
  24. olskl_dave
    olskl_dave
    Sorry to dissapoint every one ,but l just scored this,
    l'm thinking l'll go a different direction.....:confused::confused::confused::confused: At least the flathead is a runner. $$$$
    l've still gotta try and finish this freakin' thing....:eek:
    Very confused ,
    Regards Dave.
  25. HeyyCharger
    HeyyCharger
    How about this... I'll take care of the model A and the HEMI that is never ever going to fit in the Model A for you and you can finish off your Deuce... Trust me on this... :D
    Good things you've got happening Dave! Keep us posted!
    HC.
  26. 54jalopy
    54jalopy
    from Australia
    Hey man i dig the hemi, its friggin huge! And you do want to go fast?.......Right.......
