Projects Hemi or Nailhead in 1933 Plymouth
Discussion in 'The Hokey Ass Message Board' started by Spicolli, Jan 14, 2010.
  1. domepiece
    domepiece
    I'd go hemi. coming from a dodge guy whos settling on a nail in my 49 dodge because of cost.
  2. 39plymouth
    39plymouth
    Hemi!!!!!!!!!!!!!!!!!
  3. i ran a 392 in mine
  4. scootermcrad
    scootermcrad
    Yeah, if you go Hemi, I would probably advise against running the TH350. TH400 would be a better choice if you're going GM. I would again advise a 727 anyway though. Adaptation would be similar in either case.
    Can't speek for Nailheads on any avenue. Nailheads are neat in their own way, but I know pretty much nothing about them. I'm just biased towards Hemis in general, but still think it would look pretty sick in a 33 Plym.
  5. Spicolli
    Spicolli
    Wedge Hmmmm!! interesting idea!
  6. captainflight
    captainflight
    Neither. I'd go for an Olds Rocket.
  7. marfen
    marfen
    from sask
    FWIW it's not gonna cost anymore to get a 331-354 up and running than that nailhead, you're gonna make more power, it's easy to get parts since it shares so many parts w. 318-360, they're so efficient they can get over 20 mpg, and you're gonna always get heat for not putting a mopar in a mopar. you'll have no problem fitting that hemi in the 33. Run an adaptor to any mopar trans you can get, cut down any 65-75 mopar driveshaft and bolt it to an 8 3/4 out of a 66-67 b-body ply/dodge (which fit nice). Great h***le free tough powertrain...done. Frt susp. is the area you got some head scratchin to figure out on these cars.
  8. 73RR
    73RR
    Well, I 'spose the Hemi would look ok......:D...but not sure why you would put a gm trans in the middle of a Mopar drive drain. Like Scooter says, use a 727 or 518.
    If you are still looking for ideas or want something a bit different, use the Spitfire heads.
  9. 66Newport
    66Newport
    Abso-freaking-lutely!!!
  10. I SMELL SMOKE
    I SMELL SMOKE
    hemi all the way!!!!!!!!
  11. Salty
    Salty
    from Florida
    Whats the car telling you?
    Both are cool in my book....
    Then again this coming from the guy that doesnt have a machinist within 200 miles that is competent enough to work on either....
  12. Hellvedere Steve
    Hellvedere Steve
    from Coalfield
    Keep it mopar!! Hemi and a reverse manual valve body 727 would be killer!
  13. 35desoto
    35desoto
    mopar!!!!!!!!!!!!!!!!!!!!
    mOPAR OR NO CAR
    GOTTA KEEP IT IN THE FAMILY AND PEEVE ALL THOSE BELLY ****ON ENGINE GUYS OFF!!!!!!!!!!
  14. RATFINKFOREVER
    RATFINKFOREVER
    from Canada Eh
    true that
  15. Spicolli
    Spicolli
    Well looks like most people feel Hemi is the way to go! Will the big block 727 Trans bolt up to the Hemi 354/392 or do all the 727 (big block/small block) ones need the adaptor?
    I know the 331 and the 354 blocks are the same size, and the 392 is an inch taller. Is the 392 block also wider than the 354s?
    I'm going to the swap meet this week end just wanted to know what to look for?
    Thank to everyone the expressed interest in my dilemma?
  16. Spicolli
    Spicolli
    What should a good 354 sale for. Also found a 392 he's asking $2000.00 for it?
  17. Especially if you have a line on a Hemi, I would go with that:D
    Had a 354 back in the mid '60's. Terrific torque engine; had it in a '54. Lots of good parts available, check out Scooters hemi-tech and the Hotheads website.
    My dad had a '55 Century with the "big" nailhead and the old 354 could stomp him everytime. Made for some interesting family dynamics:eek:
    Luck!
  18. 34Chrysler
    34Chrysler
    MOPAR!!!!!!!!!!!!
    I am doing a 34 with a 413
    No way would I put a GM engine in a mopar
  19. 73RR
    73RR
    Although B&M made an adapter for the big-block 727 they are hard to find and usually imcomplete or have a damaged flexplate.
    The smallblock 727-518 is the way to go, and yes, they require an adapter for the block as well as the crank.
    By virtue of the 5/8" taller deck (at an angle) the 392 is about 1" wider, overall, than a 354.
    Send a PM if you need adapter info.
    Sua Sponte
  20. scootermcrad
    scootermcrad
    Wilcap has the adapters for the 331, 354, and 392 to 727-518 arrangement.
  21. jj mack
    jj mack
  22. farmer12
    farmer12
  23. 66Coronet440
    66Coronet440
    Go Hemi. It's a Plymouth, after all.
  24. storm king
    storm king
    Nailhead? Sounds like something you hammer with a hemi. Why use a footnote in automotive history when you can use the greatest engine to ever come out of Detriot and that replaced an inferior engine?
  25. Spicolli
    Spicolli
    Well I haven't had time to contact the guy on the Hemi yet!:(
    I know he has a few 331/354s and 396s! I think i will go with the 354! I really don't know what he wants as far as price yet! i figured it should go for $500.00 to $1000.00? Is that what going rate is?
    I been looking at getting the 727 trans also, look at the size of the 518 and i think the longer and bigger shift wont fit with out modifying my X member! (don't really want to change it!
    I also been thinking of going to a 700R4 (i know its a GM) but its a descent trans with OD that I think will fit. Or I can gear the 727 ant it should work fine also!
  26. HEMI32
    HEMI32
    How 'bout a Plymouth in a Plymouth? ... and keep it "traditional" with a (57-66) Plymouth Poly A series 318 ... lots of cool accessories:
    .. and stroker kits are available for them.
    Putting an early (331, 354, or 392) Chrysler HEMI in anything other than a Chrysler-bodied car is a stupid idea! :rolleyes: :D
  27. Spicolli
    Spicolli
    Don't know of any for sale! or any thing about them.
  28. Rich R
    Rich R
    from SoCal
    Hemi....I wish I would have waited to get a hemi for my 34 but I had a 350 available so in it went. I regret it. My advice...put a Hemi in it!
  29. Nick32vic
    Nick32vic
    I like nailheads better but either way, at least your putting something cool in it!
  30. Captain Freedom
    Captain Freedom
    from Upstate SC
