Hot Rods Hemi powered 33 coupe
Discussion in 'The Hokey Ass Message Board' started by griffs33, Sep 30, 2010.
  1. griffs33
    griffs33
    from Australia
    Hi all,
    I am building a 33 three window coupe powered by a 55' 331 hemi and wanting to use a Tremec TKO 600 trans using an Ansen ****tershield.
    My question is; given that the Tremec has three different shift positions which shift position will fit best, I am thinking the mid position but I am sure one of you guy's has already used this combo, so any help is much appreciated.:):)
  2. farmer12
    farmer12
    I'm also using a TKO 600 behind my 392. The shift position is dependent on far back your engine/trans will be. Like you said, this position can be changed or you could use a shifter with a bend to suit your needs. Fit the combo in the car first and then re-evaluate the shift position. Good luck and show us some pics!!
