Joined: Mar 9, 2011 Posts: 40 Profile Page TXMark Member from Wilmington, NC I'm running HOT, I have a .060 bore '56 poly 331 with 354 industrial heads 9.0 comp ratio mild isky cam high volume BBC weiand water pump 180 tsat 3core radiator 16 inch fan running hot 200 and climbing. It maybe and a bubble in the system I'm raising the radiator and tilting the motor back a bit to help, also going to run two 12' shrouded fans and an underdrive pulley on the crank, after that I don'r know where to go. the temp sender is in the back cross over port Attached Files: a"> IMG_3383.JPG File size: 92.9 KB Views: 0 IMG_3384.JPG File size: 100.4 KB Views: 0
'Hot' can be caused by several items: lack of fan shroud; not enough radiator; too much advance; water moving too fast through the radiator......Your fan blades should not go past any side of the radiator. Since I don't use any shiverlay parts on my projects, IDK what issues they may or may not cause. .
i recently fixed my over heating problems with a restrictor. water was moving way too fast through the block.
Not ENOUGH initial timing will make one bake! Common on hot rod builds when folks are using all types distributers from who knows where--the timing curves in most are way off from what you need--Plenty of initial timing makes an engine run very cool and idle like a pussycat no matter the cam--but then....you have to Limit the mechanical advance --it is simple and works like a charm. Distributors that idle with say 5-12 degree range have no place in a hot rod--get your unit idling more like 15-20 range and then limit mechanical so that at full advance it is adding just enough to get you to your desired TOTAL advance Car will run cool, idle perfect and be very responsive!
