Does anyone know where I can find out the standard main & rod journal sizes for a Chrysler 331? Were should I look for cracks on the block, main webs, etc? Anything else to watch for? Thanks
Standard for a 331 Hemi would be main 2.5000 rod 2.250 Hot Heads has more info if you need it. ~Melissa
Just copy/pasted this stuff out of my spec sheets... it's for '55 331s but I'm pretty sure it applies to all the 331's Piston Fitting; Shim to Use: .002" Pounds Pull on Scale: 5 to 12 : Ring End Gap Compression Ring: .010" Oil Ring: .010" Wrist Pin Diameter: .9842" Rod Bearings: Shaft Diameter: 2.249"-2.250" Bearing Clearance: .0005"-.0015" Rod End Play: .006"-.014" Rod Bolt Torque: 45-50 Ft. Lbs. Main Bearings: Shaft Diameter: 2.499"-2.500" Bearing Clearance: .0005"-.0015" Thrust: Center Bearing Crankshaft End Play: .003"-.007" Main Bolt Torque: 80-85 Ft. Lbs.
you could also look at classic Hemi Everything you are looking for should be here. You can use 400-455 Pontiac rods (big ends are same size have to resize wristpin.) Have been told sbc pistons will work but not sure which as wristpin height varies. On 2 of the blocks I have the lifters are frozen in the bores. Saw a couple on Ebay last night same way. Email or pm me if you want to talk some more. I'm not an expert but I have found some interesting stuff on the net. Eric =========================================================== 49 Studebaker P/U
