Hemi Tech, 392 Dist swap to 331-354
Discussion in 'The Hokey Ass Message Board' started by Gkafer, Dec 22, 2008.
  1. Gkafer
    Gkafer
    from Vancouver
    This post may not have all that much tech but it's another way to make a later dist work in a early Hemi.
    Last year I had the oppertunity to buy a NOS Roto faze distributor for my up coming 331 Hemi build. It was listed as fitting all 331-392, knowing there were different length shafts I figured if it fit great... if not the shaft could be modified.
    Once it arrived it was evident that it was a later dist for the 392. At first I thought I would just machine the shaft shorter and re notch the end. ( Hot Heads also sells a kit to lengthen or shorten a dist shaft, basicly a sleeve and some roll pins)After looking at it I thought I may want to swap it into a 392 later so I decided to have a spacer made.
    With the dist sitting in place you can see how much it sits above the block.
    A spacer ring was machined up to take up that void.
    Next a new inner bushing was machined ( as an extension to the orig one) I may machine a groove to accept an O ring for better sealing.
    Then two set screws to hold it in place, a little lock tight or a peen will do!
    A perfect fit!
    All thats needed now is to machine up a spacer for the clamp!
  2. HemiRambler
    HemiRambler
    Great idea - presserving those speed parts makes more sense now than ever!!
  3. Rich B.
    Rich B.
    from Portage,IN
    Very nice, gonna be a great looking
    motor!
    Rich
  4. power58
    power58
    Great job. Man that is one fine looking engine. Please send more pics as you go along. Thanks
  5. scootermcrad
    scootermcrad
    Fabulous Geoff!!! I'll link this up!
  6. scootermcrad
    scootermcrad
    So did you ever get this thing working? How'd it do?
