HEMI Tech: Alternator? Generator? Acc. Brackets?
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jun 21, 2006.
  1. 392_hemi
    392_hemi
    Can you find a way to shrink those photos down? I can't see much on the screen, and scrolling back and forth is making me dizzy.
  2. Bass
    Bass
    from Dallas, TX
    I mounted a GM generator down low. The adjuster arm is on the inside...It curves around the front of the generator. It seems to work just fine so far.
  3. scootermcrad
    scootermcrad
    You did what I was thinking of doing. Is that a 6-volt (I ***ume)? Did you step it up to 12-volt?
  4. desoto
    desoto
    from Ayer, MA
    One of the issues you run into with a low-mounted generator/alternator is the insufficient belt wrap on the crank pulley.
    When you don't have enough belt contact, the belt slips.
    Slipping belts wear quickly.
    Worn belts don't do their job. i.e. cool the engine (water pump) and provide enough electricity to run the vehicle AND keep the battery up to snuff.
  5. desoto
    desoto
    from Ayer, MA
    Right-click on the photo and save it to your computer then rezize it on your computer with your picture viewer.
  6. Magnus_Jager
    Magnus_Jager
    Here's my low mount mopar alternator set up. I welded up some 1/4 inch plate to make the bracket, eliminated the mechanical fuel pump, and got a nice clean install.
    notice the engine lift blocks that was to allow the modern oil filter and sanderson headers to clear the suspension. It lead to a lot of other issues.....
    The tensioner is off a cub cadet lawn tractor.
  7. George
    George
    Any ideas for a P/S pump on a 51-4 331?
  8. desoto
    desoto
    from Ayer, MA
    There are two different generators for the 51074 Chrysler. One has bushings and the other has ball bearings. The ball bearing generator has studs on the back for the power steering pump.
  9. spoons
    spoons
    from ohio
    What are you Desoto guys using for and Alt/Generator on the low-decks? Or...Am I the only one using the GM short pump conversion (276,291)
  10. Alex D.
    Alex D.
    from Hydes, MD.
    Desoto 330 Alternator Mount
    I am using the original generator mounting bracket cut and welded to a piece of 5/16 flat steel. The 5/16x18 threaded hole at the front of the head is used as a mounting point. Another brace is run to the water pump bolt.
  11. Bert Kollar
    Bert Kollar
    Here's my 270 Dodge Hemi with a late Mopar alternator. Simple offset bracket and a Summit brace
      522.4 KB
      502.9 KB
      484.1 KB
  12. desoto
    desoto
    from Ayer, MA
    I would think that, after a while, the bottom corner of that 5/16" plate would begin to pull away from the cylinder head due to the lack of an anchor down there.
    To test the theory, slip a pry bar behind the bracket and see if it flexes. If it does, you'll need to consider a bit more triangulation in the lower brace to the timing cover (perhaps out near the outer end of the bracket) or running a strap around to the front header bolt.
    The brace needs to be rigid. If you can bend it at all, all of the angular strain will be on the 5/16" bolt on the head.
  13. Alex D.
    Alex D.
    from Hydes, MD.
    I thought about the lack of a mount at the lower corner. Considering the tension is being pulled toward the water pump, the three mounting points, including the adjusting arm, would be sufficient. After some more thought, I do have to agree with you on a more ridged mount. Upon your suggestion, I have revised the mount.
    I may not know what I am doing, but that don’t mean I can’t get it right
  14. Abomination
    Abomination
  15. kisam
    kisam
    Generator, ammeter, regulator, HEI?
    Ok guys, I think I screwed up and I have a few questions. I am not willing to give up the generator or it's look on Tuffy. I know there are alernators adapted to generator cases but I question their reliability and am I going to be stranded if the alternator goes out.
    1. Did I screw up putting an HEI (inline ballist) unit with a 12 volt generator?
    2. The generator does not appear to be charging the battery. I have a 12.4 before start up and a 12.4 when it's running. Shouldn't it go to 14.6? And yes I did polarize the generator.
    3. Polarizing the regulator. When I bought the regulator I just matched up the voltage and amp rating of the original 1957 - as they did not have one in stock? Then to polarize I touched to Field to Batt (per instructions included) - but now I found a website that says touch the Amm to Batt while running? I am now thinking I have a Ford style regulator - is Mopar the same?
    4. The ammeter is an old SW 30-0-30. It stay pretty close to the middle or a little negative? I used Squirrel's suggestion and came off the battery cable connected to the starter and wired it to the negative side of the ammeter and the positive side onto the regulator Batt and onto the fuse box. I used 12 gauge wire which I am changing out this morning to 10 gauge.
    Any help is appreciated!
  16. TXMark
    TXMark
    I bought one from Jeff Sullivan $30 or $40 1/4 plate plasma cut
  17. Brand Apart
    Brand Apart
    from Roswell GA
    TXMARK, do you have anything supporting the rear of the alternator?
  18. Bert Kollar
    Bert Kollar
    100_0031.jpg 100_1116.jpg 100_1115.jpg I run a Mopar alternator on my Dodge 270 low right with a home made bracket. The tough part was spacing the pulleys (GM ) and making the lower radiator tube ( Six pieces of Stainless 1 1/2" tube from Ebay Chinese and they are beautiful and not expensive )
