Hot Rods Hemi under the bench...
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Feb 20, 2020.
  1. flynbrian48
    flynbrian48
    I rolled the 276 from the DeSoto wagon (a '52) under the bench (well, kinda under the bench, the engine is much wider) thinking someone, somewhere would want it. No one seems to think it's worth more than s**** price, so, now, I'm kinda thinking that it'd ought to be the basis of another hot-rod. I miss the '34, sold it on a whim after our wagon got rear-ended and my wife and were both a little uncomfortable in it. Now, the trauma of that has receded, I miss the roadster, and this little Hemi is calling to me. Not so much the "Gyro-Matic" transmission and Fluid Drive, , but the rest of it, yes. The engine is tight, I think it's been rebuild and never run until I got it started the day after we brought the car home. An adaptor will put a Torque-Flight or a 5 speed behind it, and I'd love to look out the ****pit of a fender-less '27 Highboy and look at those beautiful "Fire-Dome" valve covers.
    Retirement has given me much too much free time...
  2. Dick Stevens
    Dick Stevens
    Well, I've heard of worse ideas! I'll follow along to see where this goes. :cool:
  3. lake_harley
    lake_harley
    I wish I had one of those sticking out from my workbench for me to bang my leg into over and over, rather than some of the stuff I have!:rolleyes:
    Lynn
  4. primed34
    primed34
    I'm all for a hemi in a highboy, but will a'27 be more comfortable than a '34?
    SR100 and loudbang like this.
  5. Hemi's are grate motors. Just the name brings up visions of mega Horse Power. Just seeing one can bring a smile to your face. I've had more than one and learned a bit. I know that small C.I. motors are just fine under the right conditions. I also know that any automatic steels horse power and that 5 speeds aren't all they are talked up to be. I've done both combinations and I think I've gone back to a better way. Yep, 3 pedals as any Hot Rod should be. All Mopar minus the adapter. An appropriate Hurst 4 speed shifter and on top of that it's Overdrive. You must remember these little motors don't do high R.P.M's the 5 speeds are designed for.
  6. Bandit Billy
    Bandit Billy
    Is this anything like The Elf On The Shelf? Regardless you already know what I think. My only regret is my Desoto will have a hood covering it.
    I drove my roadster to work today. Even top up I love it.
    Desoto291Hemi and loudbang like this.
  7. Just Gary
    Just Gary
    Maybe you could find a stalled T-bucket project on Craigslist or eBay?:):cool:
  8. flynbrian48
    flynbrian48
    You are my hero! I had a ‘27 in my head (like the Frank Mack car) when the ‘34 popped up here in the cl***ifieds, so I went that way.
    That little car is still on my mind, the Hemi is slumbering under bench, something will come along and I’ll build it. I do have to admit the ‘34 is a nice size car, perhaps if I’d gotten around to doing the top it’d still be here.
  9. flynbrian48
    flynbrian48
    That’s what I’m waiting for. [emoji12]
    loudbang and Just Gary like this.
  10. flynbrian48
    flynbrian48
    Nope.
  11. Hnstray
    Hnstray
    from Quincy, IL
    @FlynBrian
    Glad to see you have a plan for the Desoto Hemi. For some time now I have been lusting for the Shadow Rods T Roadster. A bit bigger in all directions without losing the visual proportions.......
    Ray
  12. CAHotRodBoy
    CAHotRodBoy
    My 392 isn't under a bench but I do have it shoved in the corner of the shop. Fortunately, I already have a '34 coupe to put it in but if I didn't, I would build a car around it.
    I know a lot of guys aren't fans but to me, there is no cooler looking engine regardless of the displacement.
  13. tubman
    tubman
    I posted in the "Hot Rod Burn Out" thread about my original "T" bucket in the sixties. It had a 270 Dodge hemi with a factory 4 BBL and a stock Mopar drivetrain (Dodge 3-speed and a 4.30 rear end out of a Plymouth wagon). It was damn near indestructible and a very practical street car when driven as a two speed (2nd/high only). The combination of the light weight and high torque of a stock engine can be hard to beat.
    If I had that engine/transmission combination in the condition it is obviously in, I wouldn't hesitate to run it in a light street car. The only shortcoming I can see is the considerable bulk of the bellhousing extension, although that might be a deal breaker.
    stillrunners and loudbang like this.
  14. 392
    392
    Nothing like a early Hemi.
  15. Hnstray
    Hnstray
    from Quincy, IL
    Denny,
    If you look closely you will see that bell housing extension bolts onto the Desoto block. Only the early Chrysler (‘51/‘53) had the integral extended bell configuration. When introduced, both Desoto in ‘52 and Dodge in ‘53 were built without that. However, Mother Mopar had all that paraphernalia for the semi automatic trans and built bits and pieces to adapt it to the ‘short’ block design. Essentially what they did with the six cylinder models.
    Ray
    loudbang and flynbrian48 like this.
  16. George
    George
    If you go with the 727 I like QEC's (73RR here on the Board) adaptor.
  17. George
    George
    Mench under a bench?
    loudbang and Bandit Billy like this.
  18. tubman
    tubman
    "Hnstray" - I know what you mean about Mopar in that era. The straight stick cars used the same deeeeep bellhousing as the cars with a fluid coupling. The three speed in my bucket had an input shaft that was at least a foot long!
    loudbang and Hnstray like this.
  19. Jmountainjr
    Jmountainjr
    I would think an A883 four speed on the back of that little hemi would make that roadster a blast to drive and just about bullet proof. I believe TR Waters make is easy to do just that.
  20. 2935ford
    2935ford
    Giddyup! :)
  21. tubman
    tubman
    Unless you really enjoy "rowing through the gears", I believe that a 4 speed in a light car (like a "T" bucket) is over kill; you just don't need that much selection of ratios. I'm building my current Tub with a 3 speed with overdrive. If I want that "highway gear", I won't have to reach for the shift lever.
    Hnstray likes this.
  22. DDDenny
    Many of the 60's/70's T-bucket builds were "overkill", that was the beauty of them.
    Kind of "if a little is good, too much is just right" thinking.
    "Four speeds forever"!
  23. BamaMav
    BamaMav
    from Berry, AL
    Let's see, got a T Bird project unfinished, a Desoto wagon project unfinished, a Hemi under the bench and already thinking about a car to put it in.
    Yep, sounds like a normal hot rodder to me!
  24. choptop40
    choptop40
    High and Mighty...
  25. flynbrian48
    flynbrian48
    The DeSoto engine has the advantage over the Chrysler cousin in that the bell housing is NOT cast into the block. It's a separate piece, this one has the awful Fluid Drive coupler and weird 4 speed vacuum shifted transmission, which, if I didn't have an anchor for my Chris Craft already, would be a dandy...
  26. flynbrian48
    flynbrian48
    If a little is good, too much will be just enough. ;-)
  27. flynbrian48
    flynbrian48
    I know, it's perfect, isn't it?
  28. tubman
    tubman
    If you are planning on s****ping the boat anchor, consider saving the bell housing. It was a long time ago, but that sure does look like the one I used to put a regular 3 speed Dodge transmission against my 270 Dodge. It bolted directly to the block without the spacer. I also have a bellhousing that came on a 331 out of a '56 dump truck that looks like it could be re-drilled for another standard transmission (which I am saving).
    However, I would expect some restorer might be tickled pink to get it.
  29. randydupree
    randydupree
    from archer fl
    Ages ago i welded the clutch plate on a fluid drive to the torque converter and made it work just like a standard flywheel.
    cheap and easy.
  30. That's exactly what is bolted to my Dodge Hemi in the photo I posted above. Grate combination!
