Hot Rods Hemi
Discussion in 'The Hokey Ass Message Board' started by Hgdoo, Jan 27, 2025.
  1. Hgdoo
    Hgdoo
  2. Bandit Billy
    Bandit Billy
    It would fit under the hood of a deuce that way without firewall or radiator work.
  3. DDDenny
    My neck hurts!
  4. silent rick
    silent rick
  5. slayer
    slayer
    I'm wondering the same thing? How long do you suppose a timing chain would last with no oil running onto it? Ic seen som truly bizzar places Hemis have been used, but this one takes the cake!
    Tow Truck Tom and Fordors like this.
  6. patsurf
    patsurf
    how long does the thrust surface last?
    Tow Truck Tom, Fordors and slayer like this.
  7. Fordors
    Fordors
    Just when you think you’ve seen it all.
    This place is brilliant, the HAMB never ceases to amaze me!
    Tow Truck Tom and slayer like this.
  8. DDDenny
  9. mohr hp
    mohr hp
    from Georgia
    I love stuff that sounds impossible in theory and yet actually exists.
    Tow Truck Tom likes this.
  10. oldolds
    oldolds
    I would like to know the output of that unit. It would have to be a lot to need that much H/P to turn it.
  11. mickeyc
    mickeyc
    I recently bought a rebuilt 354 Hemi. It came with s few parts as well.
    There were a set of exhaust manifolds included that sit straight along the heads
    with provisions for capping on each end. These appear to be the or the
    same. I had ***umed they were industrial. I am thinking they could be useful
    to solve some fitment interference issue in a swap. Particularly steering. I also
    have an Industrial 331 short bell that came from the New Orleans Airport
    where it was used to power aircraft sitting on the tarmac during servicing. It has a unique speed governor system, that has an oil pump mounted under and driven by the distributor with small valves and 1/4-inch tubing to control engine speed. Totally mechanical with no electrical input. Hemis were used in many industrial applications and often featured unique components. I have never seen an account of a vertical application.
  12. lumpy 63
    lumpy 63
    Right out of High School I worked at a firm that built gas turbine and diesel generators. One odd set up we did was Vw rabbit diesels stood straight up . They were deigned for tight spaces in U.S emb***ies in south America.
  13. RodStRace
    RodStRace
    Never seen that before!
    Oiling would be my first concern, too. Guess the pan didn't matter, so they used a std. one and drain to the bottom tank.
    Seems the gen was updated to GM alt.
    Cooling seems to be missing some parts.
    What is the canister with cap next to the propane evap?
  14. George
    George
    Yup
  15. SS327
    SS327
    Some of the farmers irrigation pumps by me have big old ***mins or Detroit diesels on them.
  16. slayer
    slayer
    Im bettin it looked like this. S****ping the copper from the generator pad for the purchase of the tug and twice over, plus I got a 354. 15708.jpeg 15703.jpeg
    SS327, Tow Truck Tom and Fordors like this.
  17. Mr48chev
    If you drive the highway between Lubbock and Amarilo Tx you will see anything and everything used as pump motors. Mike PriceAt least it was that way years ago.
    I can't find the picture in my photobucket pages but one of the orchard wind machine outfits used to have an old wood wind machine stand with a Hemi with transmission with a 12 ft prop on it out on display in front of the shop. I took photos but have had too many computer crashes since.
  18. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Used to roam all over Texas. I liked the set up where the 'pump' motor was from an old pickup.
    Then they'd take the bed, flip it over to make a shelter for the works.
  19. 1952henry
    1952henry
    New one on me. Thanks for sharing that.
  20. mickeyc
    mickeyc
    The One I have is not at all like yours. The oil pump is part of the distributor. It has none of the accoutrements
    yours displays. It has the bump valve covers and Industrial lettered valve covers.
  21. slayer
    slayer
    You cant see it in the pic, but the govorner is under the distributor and connects to the throttle govorner under the carb. At sonme point on of the valve covers wqas replaced as the right bank has the industrial calve cover and the left has the firepower p***enger cover.
  22. gimpyshotrods
    gimpyshotrods
    INVISIBLEKID likes this.
