Projects Hemis in 33-34 ford
Discussion in 'Traditional Hot Rods' started by Omarsvette, Aug 27, 2021.
  1. Omarsvette
    Omarsvette
    from Arizona
    Can I fit a 331,354,392 hemi in a 33-34 ford 5 window and still use the hood? I’m using the original ch***is. What mods would I have to do?
    Stogy likes this.
  2. tubman
    tubman
    Stogy and Desoto291Hemi like this.
  3. hemihotrod66
    hemihotrod66
    My 392 is setback 11 inches to clear the blower drive and electric fan and I would need blisters on the hood...
  4. CR Newton
    CR Newton
    I have the Linderer Hemi coupe built in 1958, in Boise Idaho. It still retains the 1957 300 C 392 2x4 Hemi engine, transmission and rear axle! I can send pictures from that era. With hood blisters, fender cuts and firewall etc. it’s a Beautiful 3 Window coupe! Period correct hot-rod. It still retains the 1958 Maroon T-Bird or Lincoln paint. (801)-643-0128 Thanks
    continentaljohn and Stogy like this.
  5. CR Newton
    CR Newton
  6. Stogy
    Stogy
    Blisters are cool and well worth the price of admission and period correct as there seems to have been a need for some hood mods to accommodate the behemoths...
    I've seen some just pleasingly trimmed with the valve cover peeking out proudly...
  7. CR Newton
    CR Newton
    Coupe sat for 20-22 years in storage. The father updated a few things in 1984-86 era. Front disc brakes, wire wheels, early Sanderson Hemi headers. Then p***ed away! As you can see how dusty & dirty the car was from sitting! I had it running in 6 days, driving on the 9th day! Very smooth riding car, with the elephant sitting up front. It’s a stock frame, no boxing plates, stock radiator which keeps it cool in summertime as long as you drive it over 40-50 Mph, keep some air flowing. No Arc welding, No Mig, no Tig just Oxy/Acetylene welds. Crazy Old Coupe, I love it! The only down side is buying 112 + octane fuel so she’ll run an not hurt the Hemi, no Hardened seats an guides etc. she’s a kick in the *** to drive.
    Roger Loupias and Stogy like this.
  8. oldsman41
    oldsman41
    I put a little red ram hemi in mine fit real nice but only 241 ci. Love the little maroon job of CR newton
  9. gimpyshotrods
    gimpyshotrods
    Don't forget that the 331 and 354 have a shorter deck than the 392.
    Not by much, but it sets the cylinder heads a little closer in. Every little counts.
    Stogy likes this.
  10. Stogy
    Stogy
    https://kustomrama.com/wiki/Jerry_Berg's_1934_Ford
    :rolleyes:...Jerry Bergs Northern Star...
    Note Blister at Forward bottom hood...
    Quoted...
    "Jerry installed a monster of a completely chromed Firedome Hemi engine from a 1953 DeSoto. The DeSoto engine had been bored to 276 Cu, In. and fit with a 4-carb Weiand manifold, an Iskenderian camshaft, Mallory ignition and large valves and ports. A Cragar adaptor hooked the engine to a Ford transmission."
    Credit to Photographer, Owner
    31hotrodguy and Roger Loupias like this.
