Hot Rods HENRY J Disaster Part 2
Discussion in 'The Hokey Ass Message Board' started by swade41, May 20, 2012.
  1. swade41
    swade41
    from Buffalo,NY
    Thanks Baron, that site doesn't get updated to often on the stuff for sale it seems. That's where I found the info on the disc brake upgrade for the J though.
  2. blownhemi48
    blownhemi48
    from Bergen NY
    Is that high rpm neutral drop damage from that Falcon?
  3. redlinetoys
    redlinetoys
    from Midwest
    Zowie!!!!!!!!!!!! Glad you are ok and the car can be repaired. Looking forward to more updates!
  4. swade41
    swade41
    from Buffalo,NY
    Today i was not so sore so I found myself repairing the tube in my slick equipped Schwinn banana seat bike. After riding it a bit with my little guy, I felt like I accomplished something so I decided to try the quarter.
  5. Shane Spencer
    Shane Spencer
    dude i had a night two days ago that had me wanting to sell everything and not touch another car.... ever. just walk away for a few days, chill and come back to it. everything can be fixed. youll be thrashin it again soon. :cool: glad nobody was hurt either. **** can get real sketchy in the most unthinkable situations
  6. jgang
    jgang
    from hamburg ny
    hope everythings going well and youre feeling better phil. you will get that ***** back in line in no time. im not really good at anything automotive related, but i can fetch tools and hold ****, so if you need an extra set of hands dont be afraid to ask.
  7. swade41
    swade41
    from Buffalo,NY
    So why would these new Moser axles be increasingly harder to turn the more you tighten the retaining bolts ? The axles are the same length as the old ones, the splined end seems to go into the spool ok. They spin until you seat the bearing all the way into the housing and tighten the nuts.
    Nuts not tight, backing plate loose of course. Moser is closed until Monday so no calling their tech line until then.
  8. One Finger John
    One Finger John
    Did you verify the length of the original axles vs the new ones. You probably did but just asking. Bent housing? Bent tube? Axles bottoming out in the diff?
  9. Baron
    Baron
    I know the new axles use sealed bearings. Did the housing have inner seals possibly used with the stock axles/bearings? And make sure you don't use synthetic gear oil. It will leak past the bearings (been there,done that....).
  10. NAT WILLIAMS
    NAT WILLIAMS
    take a spot of plumbers putty stick it on the end of the axle. You need clearance. Cut to fit.
  11. swade41
    swade41
    from Buffalo,NY
    Yeah the axles are the same length as to what came out of there according to the measuring tape. I do have outer seals in the housing near the ends and did notice the new axles came with an O-ring around the bearing.
    Think that could be whats going on, the little doughnut on the inside of the bearing is bottoming out on the seal ?
  12. Baron
    Baron
    I would take an educated guess(42 years of fixing cars for a living) and say yes. The bearing retainer ring is hitting the seals. Remove the seals, put a coat of silicon sealer on the housing / bearing surface, and the axles should go right in.
  13. swade41
    swade41
    from Buffalo,NY
    Was just fishing around the google answers and it said most would leak past the bearing O-ring seals if you pull the inner seals. One even posted a quote from a Moser tech and he said that the inner seal is not required but he would run them.
    Sounds like the rtv would seal things up and since it's a sealed bearing it doesn't get oil from the housing anyway.
  14. Baron
    Baron
    I have been running no seals with o-ring bearings in all my 9 inch Fords for the last 25 years. No leaks.
  15. swade41
    swade41
    from Buffalo,NY
  16. FlynBrian
    FlynBrian
    Good Luck! I have a few that need a blessing also...
  17. lippy
    lippy
    from Ks
    Most of mine need a smashing. LOL. Lippy
  18. swade41
    swade41
    from Buffalo,NY
  19. swade41
    swade41
    from Buffalo,NY
    Pulled those inner seals and everything is good to go now, there was a .30 difference in the length of the outside bearing to outside retainer ring as compared to the other axles. Moser said with the O-ring bearing you don't need the inner seal anyhow but I did put a little rtv in there as Baron suggested.
  20. Baron
    Baron
    Any news on the Henry J (Good, I hope)?
  21. Hdonlybob
    Hdonlybob
    Talk about a long and bumpy road !
    Glad to see you are really sticking with it to get it figured out.
    Hope this is the last problem for you.
    Good luck,
    Cheers.....
  22. rustyfords
    rustyfords
    from Conroe, TX
    My dad started drag racing in the 50's and had me behind the wheel at age 14.
    I/we tore up everything we ran, in one form or fashion....bent body panels, exploding clutches, you name it.
    As long as it's not totaled and you're still moving under your own power, it's all good.
    Replace that axle and run it with the body damage until you get the time to straighten it out. Those in the know will love seeing it there with the war wound intact.
  23. swade41
    swade41
    from Buffalo,NY
    I had planned on racing today, but dropping over a half a grand on dailey driver repairs (gotta keep momma with wheels) yesterday means no budget for racing. I hope to get the car to test and tune maybe Tuesday at the local track to see how it works.
  24. rustyfords
    rustyfords
    from Conroe, TX
    Glad to hear that you're moving forward.
    And I totally understand the daily driver repairs....they're kicking my tail right now too. I have a transmission from an Odyssey torn apart in the garage and need to clean out some @$%@#$ thing called the Idle Air Control Valve in a 98 Accord.
    But, I don't do debt and therefore drive used cars that need attention.
    Looking forward to hearing about your first run down the strip.
  25. 55chieftain
    55chieftain
    Hi Phil just found this thread, too bad about the car. As mentioned at least the axle broke on the line instead of down the track. Have you checked with a body shop with a frame machine, they should be able to pull that out. Best of luck , Bill
