Henry J firewall help
Discussion in 'The Hokey Ass Message Board' started by 327Eric, Jun 16, 2012.
  1. 327Eric
    327Eric
    [​IMG]Hey guys, I am looking for some advice for strengthening my firewall on my 53 Henry J. As I am trying to correct the mistakes of my over enthusiastic teen years, and finish my Car off, I have run into an issue on my firewall. I cut the whole front of the firewall off, and set it back to be flat with the dash. as a result, i have a lot of flex in the front corners. I am planning to gusset the stock body mount to the frame, and reinforce the inside of the firewall with some falt sheet metal, similar to what the factory did around steering column and master cylinder mounts. I am not the greatest fabricator, so any ideas or Pictures would be great.
  2. blue 49
    blue 49
    from Iowa
    I don't know if this helps, but this is where I'm at now. I think once I get the toeboards and transmission tunnel tied in it will be pretty sturdy.
    blue
  3. 1971BB427
    1971BB427
    from Oregon
    Flat sheetmetal will have less strength than sheetemtal with contours, or ribs. You can fill in the missing parts and press in some ribs to strengthen it, of go heavier gauge if ribs aren't an option.
    I built mine around the engine and close. Put an offset in the distributor area that really made it all much stronger. I also used 16ga. to further strengthen it.
  4. zzford
    zzford
    Install a X made of 1/2" square tubing.
  5. plodge55aqua
    plodge55aqua
    from Alberta
    Maybe you might have enough room on the inside to spot weld hat strips.. and keep the out side clean.. I miss my J already..
  6. bulletproof1
    bulletproof1
    from tulsa okla
    id like to see from the inside,,how much foot room did you loose,,alot of Js ive seen the move the seat way back from the dash....dont want to do that with mine...
  7. 327Eric
    327Eric
    Thanks for the input. Now i have some ideas to play with. Bulletproof1, the firewall is flush with the Dash-there is no footroom as the stocker had. I eliminated the back seat, and set the front seat back about 12 inches. There is still enough room to hang my arm out the window.
  8. kidd65
    kidd65
    My Henry J has a new firewall fabricated with seams and angles so strength is not a problem. Not much foot room, though.
  9. badshifter
    badshifter
  10. Marty Strode
    Marty Strode
    I am with Badshifter, I never set an engine back any farther than needed. I like to retain the most foot room as possible. In your case I would use ZZ Ford's idea of a 1/2 or 3/4" square tube structure on the inside, "plug welded" on the engine side, then skin the inside with some light aluminum, leaving a space for some foam sheet insulation sandwiched between, That would make a good support for pedals. This is one I did recently with a Small block Ford, just as a comparison.
  11. 327Eric
    327Eric
    The setback is the result of teenage dreams. It is one of many mistakes made.
  12. nutajunka
    nutajunka
    That doesn't look too far back from the angle I'm seeing. Looks like your number 1 plug is still over the top of the axle. Just remember that your fire wall doesn't have to be flat all the way across unless you want it to be.
