Technical Henry J Frame Question ?
Discussion in 'Traditional Hot Rods' started by Psycho Deville, Sep 27, 2024.
  1. Hey Gang!!
    I am looking to build an early 60's Henry J gasser and I am looking for suggestions for frame and suspension techniques.
    This is our first time at this type of project and I have a real decent body to start with. I also have an F1 frame and really nice F1 axel with the springs. Not sure if that is the way to go.
    Thanks!
    J.
  2. alchemy
    alchemy
    Building a Henry J truck? With a bed in the back?
  3. Great question, thank you.. No, I am not
  4. I think that mite work, the F-1 frame isa typical ladder style frame,...take some measurements to see how it'd come together.,...probly have to shorten the frame
    can we see some pics of what you got?
  5. Stock frame will work too
    69fury and dana barlow like this.
  6. A Boner
    A Boner
  7. 29Sleeper
    29Sleeper
    from SoCal
    If you have no Henry J frame I'd build one from 2x4 tubing. If you put much horsepower in it you'll need to at least box the F1 frame. Use parallel springs in the rear and a cross spring in the front due to the short distance from the nose to wheel CL.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    @HJmaniac may be of help.
    You'll probably want to narrow the axle about six inches; drill the I-beam.
  9. oj
    oj
    Are you building a race car or street, what engine and how fast do you plan to run?
  10. 1971BB427
    1971BB427
    from Oregon
    If you're building a Henry J gasser the stock frame is great, and will work much better than trying to make a donor frame look good under it. I would suggest it's a good idea to stub the Henry J frame rails so you've got a nice clean, straight front frame rail to setup your axle and motor mounts.
