Projects Henry J Southeast Gassers build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Jan 16, 2016.
  1. Uncledirty616
    Uncledirty616
    Yeah, it kind of worked out that way. I keep thinking, "maybe i could make Greer" but realistically spring.
  2. Uncledirty616
    Uncledirty616
    Got to set it down on the springs today. Looks pretty good. It does sit higher then i hoped but i dont have anything in the car yet, so i am ***uming some settling will occur. 14362518_10207332972867006_229911810421362187_o.jpg
    Dog_Patch and mad mikey like this.
  3. Higgy's Henry
    Higgy's Henry
    What spring rate are you starting with?!
    Uncledirty616 likes this.
  4. Uncledirty616
    Uncledirty616
    125? does that sound right? It was the lightest they had. I was expecting them to settle to 8" they only went down to 9.5" but as you can see there isnt much in the car.
  5. Higgy's Henry
    Higgy's Henry
    Sounds like a good starting point. Southern Flyer was running spring rates in the low 100's, talked about it just recently in his thread. He was trying a bunch of different springs. Not sure he posted his findings but he is always helpful!!
    Dog_Patch and Uncledirty616 like this.
  6. Uncledirty616
    Uncledirty616
    Got everything on but the shock mounts, gonna throw those on and then pull it, and finish weld everything. Here it is with the panhard bar, i made it long on purpose. I can always shorten it. 14352049_10207333394757553_6956166864593474195_o.jpg
    mad mikey likes this.
  7. Higgy's Henry
    Higgy's Henry
    You gonna run A or C, I don't remember if you said.
  8. Uncledirty616
    Uncledirty616
    running A/gas. I am a little concerned about weight, but we will see. I weighed it a while back when it was similar to how it is sitting now, no front clip, but a iron headed engine, with no rotating ***embly, T5 trans, and i think an old aluminum bell housing (strictly for mock up) no cage but steel floors. and it weighed 1540 if i remember right.
    Higgy's Henry likes this.
  9. Higgy's Henry
    Higgy's Henry
    Keep your eyes peeled for a spare headlight ring. I missing one.
  10. Uncledirty616
    Uncledirty616
    K will do.
  11. Uncledirty616
    Uncledirty616
    finished the rear end 14524473_10207428391092402_5287974832714641403_o.jpg last night. It gets sent out Monday to have it normalized.
    Dog_Patch, swade41, loudbang and 5 others like this.
  12. Uncledirty616
    Uncledirty616
    Santa brought me knew (used) offset lifter for the Henry J! 14480562_10207460852463916_2985623410310676724_o.jpg
  13. Higgy's Henry
    Higgy's Henry
    I think he got his address' mixed up! Those were supposed to come here!
    sonic03bluegt and Uncledirty616 like this.
  14. Uncledirty616
    Uncledirty616
    What you runnin for heads on yours?
  15. Higgy's Henry
    Higgy's Henry
    Pontiac heads that were supposed to end up here but ended up in MI somewhere!! lol I have the old Dart cast iron heads, might be looking for an upgrade to aluminum with big runners for a big cam though......
  16. Uncledirty616
    Uncledirty616
    I do sell parts , and can usually beat prices on Dart products.
  17. Uncledirty616
    Uncledirty616
    got the front clip back on the car, and got the rearend back from heat treat ( I had it normalized) just need to decide whether i will paint suspension parts a color or black....decisions decisions.
  18. Uncledirty616
    Uncledirty616
    Got the Rearend housing painted, it will be going out to the builder this week. Should only take him a month or three to finish it up from here, he is really fast ;) 14525084_10207501660924102_5089724575427102482_o.jpg
    Dog_Patch and loudbang like this.
  19. Uncledirty616
    Uncledirty616
    And, got the front clip back on and checking to see how the front is sitting now that i lowered it. I am pretty happy. I would like it a fuzz lower, but cant do much at this point unless i want to start redesigning stuff...not so much. I think the car will probably settle a little also. there is still a lot of stuff that needs to go back into the car. 14543726_10207501676764498_5264592729798699746_o.jpg
    AHotRod, Dog_Patch, Saxxon and 7 others like this.
  20. GassermanBob
    GassermanBob
    So wheres the updates? Cant wait to see it run in the new Season
  21. Uncledirty616
    Uncledirty616
    Awesome!!! Keep on Him Willy! Hey by the way, did you hear? D/gas is 10 pounds per cubic inch,,,,you got your wish after all. =) Slow progress that last couple weeks, back in school. But hoping to make some big gains in the next week or so..
    volvobrynk likes this.
  22. D.N.D.
    D.N.D.
    Boy you guys are lucky with the lighter weights, in 64' I had to weigh 9 lbs to run B had 700 lbs in it to make cl***, then in 66' they took 2 lbs off and I took the 700 out and ran at 2300 lbs for B
    Had a 3/8" steel plate welded between the rear frame rails using a very large Buss Battery and 3 big pieces of lead bolted to the plate
    When they went to 7 lbs I put in a reg size battery and a water tank to help cool it down using a bait tank pump
    The water tank worked great as 3 runs in a row on a hot summer day it would get pretty hot with the small Crosley radiator, just turn on the little pump and watch the temp gauge come right down
    DND
  23. Uncledirty616
    Uncledirty616
    Worked on the heads today. Honed valve guides (forgot how messy and nasty that job is lol) 15138482_10207875441948394_5064879403500437083_o.jpg
  24. Uncledirty616
    Uncledirty616
    And started on roughing the seats in so i can start porting the heads. 15235515_10207876629418080_6192987386254461971_o.jpg
  25. mad mikey
    mad mikey
    I like your rear suspension , my coupe has a very similar set up, and it works great.
    Uncledirty616 and loudbang like this.
  26. Higgy's Henry
    Higgy's Henry
    I believe they are Pontiac 867 heads.
  27. Uncledirty616
    Uncledirty616
    Yep, they are Pontiac 867s. Which is basically the predecessor to the Brodix 10x head. their are many versions of this head, mine are the plain Jane 23degree ones.
    Higgy's Henry and loudbang like this.
  28. Uncledirty616
    Uncledirty616
    I can't lie, i am basically "borrowing" Heavily from what Quain Stott does with his cars. (IE, im copying him)
  29. Saxxon
    Saxxon
    Imitation is the sincerest form of flattery
    It's not plagiarism, it's team work
    If you imitate one you're unoriginal, if you imitate many it's research
    You know you're winning when you're being copied
    Imitation is at least 50% of the creative process
  30. Uncledirty616
    Uncledirty616
    Thank you ...I think? ;)
