Henry J Straight Axle Question
Discussion in 'The Hokey Ass Message Board' started by Kustom Chief, Apr 26, 2007.
  1. Kustom Chief
    Kustom Chief
    I just scored a Henry J to build a g***er. I was wondering if anyone knows what axle and springs they used in the old days, before speedway had a kit. Also, Anyone have an idea on a read that would fit? Early Bronco? I will probably have an early Pontiac cut down to fit but it never hurts to ask.
    Larry
  2. Omega
    Omega
    from Mass
    Maverick rearends are pretty damn short, but finding a good v8 one is a *****. Plus i think there 8 inch,,
    Econoline front axles were pretty popular
  3. DeepSouthRick
    DeepSouthRick
    Back "in the day," we used Econoline axles and springs.
  4. There's a few Henry J g***ers pictured on g***ermadness.com which are set up with Ford Model A crossmembers / front axles. Carl Hagan
  5. rooman
    rooman
    Larry,
    an early Pontiac rear may be period correct but getting parts may be difficult in this day and age. I hate to suggest a 9" Ford but they really are the easiest as there is so much out there for them. A Dana 60 is a little cheaper and again, lots of stuff from lots of vendors.
    Roo
  6. 2manybillz
    2manybillz
    I think an early Ford and transverse spring is your best bet, crossmember could be round or square tube or channel. Econoline or other parallel spring axles may have too wide a track for a Henry J, you could narrow one though, it was done that way also.
  7. hotrod1940
    hotrod1940
    My Henry J in the sixties had a 40 Ford front axle and spring with split wishbones mounted 12' forward of the Henry J original wheelbase. Back then it was A gas, but now would be an altered or what ever fancy name they have now.
    Loved that car.
  8. Kustom Chief
    Kustom Chief
    Thanks for the input....I am trying to figure out what to do....I have access to all those suggestions (econoline, 40 ford, model A). I know it would be easiest to run the Speedway kit but I keep thinking about what will look "right". The car will have either a early 389 or a 401 Nailhead.
    As far as the rears, my father wants me to run the early pontiac rear. I know I have access to a couple. I even have a pumpkin with 4:88's in it...totally unuseable but cool. I am super amped for the car. It has given me a push in getting some other **** on the road. After the push truck, either that or the 53 Bel Air will be next in line. Somehting tells me the Henry J will be an easier project. I want to keep it simple but also correct.
    Larry
  9. rusty1
    rusty1
    ...we need pics.
  10. hotrod1940
    hotrod1940
    Just for more info, my Henry J was Caddy powered with dual 4barrels, Chet Herbert roller, Lasalle Trans and Plymouth station wagon rear.
    Ford front extended12 inches and 6 inch slicks.
    At the starting line, rev to 6000, pop the clutch in second gear. The slicks broke loose and when the tach reached 6000 again, shift to third and it would hit 6000 again exactly in the lights.
    1959 best time was 12.93@117 MPH
    I blew the engine racing the car's original owner who had moved on to a Willys 4dr. sedan, also Caddy Powered.
  11. Kustom Chief
    Kustom Chief
    Pics will come when I get the thing home. I am dying to see it again myself! Larry
  12. HenryJGuy
    HenryJGuy
    from Dayton, TN
    I think an early Ford axle is the best bet. I'll be running a '40 Ford axle with a transverse spring...mainly because I found one cheap and it will be easy to fab up a cross member and spring hanger. Make some mounts for the wishbone, use a Vega cross steer box and away you go. Juice brakes if you want to get fancy or no brakes for the REAL drag race look.
  13. Kustom Chief
    Kustom Chief
    Have any pics HJGuy? Would love to see anything. Larry
  14. Larry, Did you pick up the henry J from a guy named Glen? Just wondering....
  15. Frosty21
    Frosty21
    from KY
    I looked at one a friend of mine had, all front sheetmetal was missing along with the engine, so I had a good look at it.
    Looked like paralell leafs and beam axle out of an 50's ford truck, I've seen alot of those, and I'm pretty sure thats what it was. The track didn't look too wide and there wasn't very much frame hacking for it to fit.
  16. Kustom Chief
    Kustom Chief
    No. Not glen....
  17. FoMoCoPower
    FoMoCoPower
    an early Bronco axle would it a 4x4....
  18. zimm
    zimm
    from iowa
    well i scored a 47 truck axel to use under my comet but it pairalel leaf witch i would prefer. why the transverse?
  19. chitbox dodge
    chitbox dodge
    from dunlap tn
    doesnt MAS fibergl*** have a drop axle set up that would work? i do remember that they had a tube axle with twin leaf springs. i think it was knuckle to knuckle so i guess youd have to find hubs and brakes and all, but it wasnt real bad expensive either.
  20. HenryJGuy
    HenryJGuy
    from Dayton, TN
    I will have pics sometime soon. I haven't put it under the car yet. I'll have plenty of pictures and might do a tech article on it for good ole' Rodder's Digest.
  21. '63 VW front end... cheap, lightweight, and didn't steer for ****....
  22. Kustom Chief
    Kustom Chief
    A king pin front beam? I don't think so. I am going 99% with a 40 ford set up.
    Larry
  23. zzford
    zzford
    One way that I've found to get a narrow rear cheap is a Dana 44 out of a Jeep CJ. I've used a couple of them thru the years. Bonus, many of them have early Ford bolt pattern.
  24. Kustom Chief
    Kustom Chief
    I think we are goign to cut down a 60 pontiac rear i have....Progress.
    Larry
