Projects Henry J
Discussion in 'The Hokey Ass Message Board' started by 27 Tall T, Nov 9, 2025.
  1. 27 Tall T
    27 Tall T
    from Butler Pa.
    Looking for options on how to finish rear wheel well opening on a Henry J. Thinking on using 1/4 or 3/8 steel rod or 3/8 .035 tubing. 20251103_181632[1].jpg
  2. Motorwrxs
    Motorwrxs
    Maybe Swade41 will chime in here…he’s got a pretty cool Henry J.
    427 sleeper, swade41 and catdad49 like this.
  3. catdad49
    catdad49
    Conduit is a lot easier to shape.
    SS327 likes this.
  4. pprather
    pprather
    swade41 likes this.
  5. Conduit. Split it and slip it over the opening edge.
  6. blue 49
    blue 49
    from Iowa
    I rolled a radiused bead and pie-cut it to conform to my quarter. Spot welded it on. It didn't stand-off enough to be above the stock side spear so I added 3/8" tubing along the inside edge.
    .... and now.
  7. BigRRR
    BigRRR
    Question about using conduit?
    I know I have seen a lot of old photos of guys using electrical conduit to build custom work. And have thought of using it myself, but today’s conduit is so heavily galvanized. Am I missing something? How do you remove the galvanize or is there non-galvanized conduit?
    Thanks Ron
  8. blue 49
    blue 49
    from Iowa
    My original quarters were done with conduit. Pretty ugly up close. early mock up 2.JPG
    oldiron 440 likes this.
  9. SS327
    SS327
    Just grind off where you’re going to weld. Conduit is traditional.
    catdad49 likes this.
  10. swade41
    swade41
    from Buffalo,NY
    On mine I used 1/4 in or maybe it was 5/16 brake line I shaped around my t-bucket tire
    Taped in on there and started welding, after I blew through the line in the second spot I was wishing I had used solid rod instead of the thin wall tube.
    Little filler and it all looked good and holding up really well 15 years later. I do like the conduit idea but I couldn't see how I could bend a perfect circle then cut a perfectly straight line around the radius. Plus the fact that the quarter panel shape isn't perfectly flat, so how to shape the conduit to that after you've bent it and cut it.
    I'm a caveman over here on tools so I just used some brake line. Lol
  11. swade41
    swade41
    from Buffalo,NY
    Just don't breathe the fumes while grinding or welding it, I guess it's toxic (but what ain't). I used conduit to make inner structures on a couple tilt front ends, including the Henry J.
    papajohn, 427 sleeper, SS327 and 4 others like this.
  12. Dave G in Gansevoort
    from Upstate NY
    If you don’t want to use conduit (emt) you can get steel dom tubing with about the same wall thickness as conduit. 3/4-inch X 0.049 dom is available from most steel suppliers. And it’s safer to weld on as it’s bare steel.
  13. mohr hp
    mohr hp
    from Georgia
    And a whole lot better quality metal.
  14. Dave G in Gansevoort
    from Upstate NY
    And that too
  15. cabong
    cabong
    Nick's '51 uses the factory body line as a guide, then formed the opening from sheet metal. Needless to say, this critter gets used a lot !!!! winner nick.jpg
    Ken Smith, catdad49 and loudbang like this.
  16. 27 Tall T
    27 Tall T
    from Butler Pa.
    I used 3/8 OD tube, and 1/8 steel rod for lower sections, then some Duri gl***.
