Technical HenryJ disc brake bracket
Discussion in 'The Hokey Ass Message Board' started by henry's57bbwagon, Aug 27, 2023.
  1. henry's57bbwagon
    henry's57bbwagon
    I have designed brackets for the front spindles on my 51 HJ and wondered if there are other brackets that would fit the 4 bolt holes instead of making them?
  2. swade41
    swade41
    from Buffalo,NY
    The only ones I ever seen were the ones that someone came up with on the Henry J cars website.
    I'm not sure why they were made in two pieces instead of one.
  3. henry's57bbwagon
    henry's57bbwagon
    Thanks Phil. That is the style I started out with. Probably 2pc to save material.
    I have the drawing from the origonal article but I made my dwg with the caliper at a 30* angle.
    swade41 likes this.
  4. jimmy six
    jimmy six
    If you have the design even in cardboard getting them cut on a water jet is not too big of a deal. I would make one piece because it will be stronger and put the caliper at 2:00.
    I’ve done header flanges that way and supplied the 3/8” plate I wanted.
