Customs Her name is Cherry, cuz she ain't
Discussion in 'The Hokey Ass Message Board' started by Suicide-D, Apr 30, 2011.
  1. Tin Can
    Tin Can
    You could put some bump stops inside or next to your notch that stop on top of the rearend. That may be easier than creating another crossmember in the rear. This is what I was planning on doing with mine.
  2. Suicide-D
    Suicide-D
    from Texas
    Hey, That would be easier..Why didn't I think of that?
  3. 60galaxieJJ
    60galaxieJJ
    Damn I love this thread so far
  4. Midwest Rodder
    Midwest Rodder
    Great job so far!
  5. More likely cleaner running too..
  6. why not add a couple of drop blocks between the axle and trailing arms?
    take a look at the jiminez bros. customs site and look at their set up. no cutting. you should be able to work it out. also they did an install on a similar frame in rod and custom a few months ago.
  7. Suicide-D
    Suicide-D
    from Texas
    As you can see I had to step the a-arms. I didn't want to do this... but I wanted to spend 500 bucks less on dropped uprights and steering arms so I compromised with myself.
    guessing at ride height
    moving on to the rear next....
  8. J.Barrett
    J.Barrett
    I like it so far, glad you didnt go with the gasser idea. I have one suggestion, and you might already have it planned. where your front suspension bolts to the frame, plate it to the frame, when you cut for bag clearance you remove alot of material, and it will bend making your camber go to shit. Speaking from personal experiences. here is a picture of mine.
  9. Suicide-D
    Suicide-D
    from Texas
    I do plan on bracing it to the frame. I wanted to wait until i have the motor in. Thanks for the reminder
    Sent from my iPhone using TJJ
  10. Suicide-D
    Suicide-D
    from Texas
  11. Suicide-D
    Suicide-D
    from Texas
    got a little time this weekend. Pay no attention to the dirty motor...it will be rebuilt. I set the motor in and fabbed up some mounts. I had these chassis engineering v-8 mounts from the purchase of another car a few years ago so I used half of them...split some tubing and cut the rest out the plate.
    I need to make a trans crossmember now.
  12. Suicide-D
    Suicide-D
    from Texas
    Did some work on the trailing arm crossmember. I expect to have this rear end done this weekend.
    I bought a sheet of 18 guage so I can get started on making the floors!
  13. Suicide-D
    Suicide-D
    from Texas
    sick of me yet?
    I got the k member out. trans crossmember welded in. all the rear stuff is tacked together.
  14. 60galaxieJJ
    60galaxieJJ
    Smart idea
  15. Keep in mind that the panhard bar is gonna move the axle (and truck arms) sideways some when you lay it out. Make sure your stops line up on the arms when it's all the way down. Think I'd wait on those until you have the panhard in just to be sure where the axle is gonna move to.
  16. Suicide-D
    Suicide-D
    from Texas
    Yeah, I did think about that after I posted that. I have resolved to doing the stops as Tin Can suggested and put them in the notch. I picked up some Energy Suspension bump stops from Oreilly's.
    I think the panhard I have is too short...
  17. greasebandit0801
    greasebandit0801
    from houston
    yo D nice work i live in katy too keep up the post
  18. Suicide-D
    Suicide-D
    from Texas
    Thanks. Another [edit:fleetline] in the area??? I just noticed it's a coupe? hard to tell in the avatar
  19. greasebandit0801
    greasebandit0801
    from houston
    Had her for about 10 months just haven't had time to finish the chop
  20. Suicide-D
    Suicide-D
    from Texas
    I had to move the car to storage this past weekend. I was kinda burned out on it and was thinking about selling it. My son needed more room in the garage while working on his mini truck. The sacrifices we make for our kids, right? Anyway, I had to put the body back on the frame to accomplish the move. That's all it took. I'm in love again. Now to get that mini truck out of my garage!
    I'm not real stoked about the frontend though. like I said before those bags are huge. and rub on everything. These tires are also 2" bigger than the ones I would like to run.
  21. so why not just run some smaller bags?????
    if you HAVE to have the big bags, look up the baggin a stock 49 front end tech in the archives. there is a guy who did a control arm mod to compensate for huge bags.
    keep it up. stay with it.
  22. Suicide-D
    Suicide-D
    from Texas
    That's what the boy keeps telling me also. I will get some Slams with the internal bump stop. Now I will have to bag something else to use the D2500's...
    I will keep it up now. I ordered the disc brake parts and king pins over the weekend. Since I'm running a Ford rear end I wanted a Ford pattern on the rotors.
    I ordered a disc brake conversion last year and it has GM bearing adapters.
    Here's a solution in case someone is interested:
    1977 Granada rotors.
    1973 ish GM (Camaro) bearings
    The Granada rotors have the same bearing race size as the GM. The bearing adapters will fit the GM bearing.
    I will confirm the numbers once I have all the parts assembled.
    Thanks.
  23. Suicide-D
    Suicide-D
    from Texas
    Six months and $780 in storage fees later...my girl is back home. I have 6 weeks off from school...think i can get her on the road?? Lets see.
  24. awww yeah! Get after it!
  25. PA-IndianRider
    PA-IndianRider
    Why would you think that????
    Having a RADICAL engine in a gasser styled car that can be classified as STREET (just barely) / STRIP (seeing occasional drag strip time - nostalgia - HAMB - Gasser Reunions drags, etc) is the way to go.
    In fact, building a STREET GASSER might be the BIGGEST TREND in hot rodding today.
    See the latest Rod & Kulture magazine for an article about HAMB member KiwiKev and his awesome home built street-driven real-deal wheel-standing gasser..... Nasty Habit!
  26. Time to get rolling along and finish it
  27. Suicide-D
    Suicide-D
    from Texas
    Well I'm having my cake and... not to be trendy but I am building this also..
  28. PA-IndianRider
    PA-IndianRider
    NICE...... Looks I need a "score card" to keep up with all your doing..... looks like you have quite a few hot rods to keep you busy.
  29. t-buckethead
    t-buckethead
    from texas
    come on now,mine is now registered and insured,here is some motivation...
