Projects Here I go again, but this time it's a Mopar.
Discussion in 'The Hokey Ass Message Board' started by out plowing, Apr 5, 2023.
  1. out plowing
    out plowing
    Late 20s Mopar chassis.
    I'm thinking a 250 flathead dual or triple carb, split exhaust.
    I'd love find a set of buffalo wires, but I'm not certain my pockets are deep enough yet.
    As for the body, boat tail perhaps.
    Only time will tell...
  2. Let’s see now, you’ll need at least 3 97s , split manifold, a pair of Smithy’s ( hey, if you’re gonna build an inline 6 it’s necessary) , 3 speed transmission, Halibrand Q/C rear end, oh and at least legitimate excuse to drive it like you stole it. He he.
    Tow Truck Tom and VANDENPLAS like this.
  3. gene-koning
    gene-koning
    Probably are not going to want to keep those wooden spoke wheels, but they do look cool!
  4. Lloyd's paint & glass
    The first model A I had, i found it in the middle of the woods at an old clay mine. I was told there was a frame sitting there, and there was, it had been turned into a trailer, but after searching around I found the 4dr sedan body that came off of it. :D
  5. A 2 B
    A 2 B
    from SW Ontario
    Those wheels would make for a killer facade on a bar front in the man cave.
  6. Budget36
    Budget36
    If you’re curious of the year of the chassis, I bought a set of DB wood spoked wheels 20+ years ago do just tell DB screw on caps. Anyways, I went to the library and ID’d them via two publications. I’m almost sure they were “The standard catalog of light duty cars” and “the standard catalog of light duty trucks”. Within the books, it had the bearing inside and outside dimensions for each year model (of all makes) from real early up through the late ‘30’s if memory serves.
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Keep on bringing the crops in, for when those Buffalos show up
    All best, gotta be fun to make a rebirth
  8. 210superair
    210superair
    from Michigan
    Looks set up for one horse power.....
  9. dwollam
    dwollam
    It is later than 1927 if it is a Dodge Brothers. Prior to that they had 6 and 7 lug rims whereas that has 4.
    Dave
  10. twenty8
    twenty8
    I'd say more like two. Looks like a twin yoke setup to me......
  11. Rickybop
    Rickybop
    Hello Mopar brother.
    Pretty heavy duty frame, huh.
    You've got front brakes. Mine's a 1926 Dodge and no front brakes. I think yours is 1928 or later.
  12. rusty valley
    rusty valley
    Whats it sitting on, your tornado bunker? I've drug home several old wagons and they are usually pretty beat up. Your's looks good !
  13. out plowing
    out plowing
  14. out plowing
    out plowing
    Nope, cold water storage for the old milk cans.
    SS327, chryslerfan55 and rusty valley like this.
  15. 41 GMC K-18
    41 GMC K-18
    Regardless of what this chassis turns into, definitely save those vintage wood spoke wheels, maybe use a little Danish oil on the wood spokes to help them come back life.
    They are very cool for decorative purposes that you have not thought of, or discovered yet!
    out plowing likes this.
  16. Squablow
    Squablow
    Any build that would make use of this chassis, I like.
    out plowing and 41 GMC K-18 like this.
  17. dwollam
    dwollam
    I have a '27 DB coupe that I have been thinking about later ('33-'53) running gear. My measurements shows a Mopar flathead 218/230 six to be only a 1/2" longer than the stock 4 banger. I have an '50's engine and 3 speed trans and rear axles and a '33 front axle etc that would make a nice driver and still look fairly stock and have about 4 times the horsepower, brakes and steering. All Mopar warm rod.
    Dave
    41 GMC K-18 likes this.
  18. out plowing
    out plowing
    Well found a casting number, still no help to determine if Chrysler or Plymouth. 3 of the 4 rims are saveable. But the frame has butchered right at the rear axle front spring perch.
