Here we go again! Another "What's it worth"...5-window!
Discussion in 'The Hokey Ass Message Board' started by brett4christ, Nov 30, 2012.
  1. brett4christ
    brett4christ
    I have the opportunity to buy this:
    I'm 99% sure that all the fenders are there, pretty sure about the trunk and doors, and 50/50 on the hood & sides. Also fairly definite that one of the frames in the background is for this.
    BIG Q.....what's it worth a) with ***le and b) without ***le?
    I know it's worth what someone is willing to pay, but I don't want to pay out-o-the nose!
    Thanks for all constructive input!
  2. alchemy
    alchemy
    It makes all the difference in the world >>> how rusty/bent is it?
    Based on the parts you listed, it could range from $200 to $6000.
  3. Kirk Hanning
    Kirk Hanning
    5 yrs ago I bought a rough meaning no floor and needing every patch panel for $1000. It was the shell, doors, fenders and deck lid. I consider my buy a good deal.
  4. TexasDart
    TexasDart
    yeah but this is the sunroof model. Those are really rare. :)
    Is that a 40 ford?
  5. brett4christ
    brett4christ
    Al
    The body has been in this general position for quite a while.....probably years. I would imagine the subfloor is swiss cheese or worse. The body itself is much more straight than not, but I haven't really had a chance to look at the problem spot...the rockers/lower cowl/lower quarters. If I recall correctly, there's minimal rust above 6 inches from the ground.
    The rear fenders are pretty nice, not sure about the fronts.
    How much closer can we get now? :D
  6. oldolds
    oldolds
    Looks to be worth about $12.00/ 100lbs.
  7. brett4christ
    brett4christ
    TD
    Unless I'm grossly wrong, it's a 35/36!
  8. 49ratfink
    49ratfink
    in order to guess what's it worth we need to know what is there and what condition. anyone who guesses based on the information given is just pulling a number out of there ***.
  9. roundvalley
    roundvalley
    Lets go about it another way. How much does the seller want for it with or without ***le??
  10. brett4christ
    brett4christ
    Oldx2
    REALLY!?!?!?! :D
    No, this thing is definitely worth saving! My idea would be to build a LSR/drag-style fenderless car with a track-ish nose and smooth hood and hoodsides, but that's if the front sheetmetal can't be found. If it's "all there", it should be an early post-war hot rod, full fendered and all!
  11. Saxon
    Saxon
    from MN
    35/36 - leaning 36. Rear fenders are worth a few hundy if in good shape.
  12. HOTRODPRIMER
    HOTRODPRIMER
    I'm thinking it's a 35/36, in the 500 to 1,200 price range. HRP
  13. brett4christ
    brett4christ
    RV
    I'm not sure, but I am planning to take just enough $ to buy it and see how it works out.
  14. brett4christ
    brett4christ
    HRP
    Is the $500 including the frame but no ***le?
  15. -Brent-
    -Brent-
    Go low, Brett. That thing will nickle-and-dime you for all the little things. The dash/guages, alone, could get spendy.
  16. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    A 35-36 SHOULD ABSOLUTELY NEVER NOT HAVE FENDERS.....ever. If you buy it plan on spending the money for the fenders and grille. They're turds without.
    I'd say, why take on another project when you have two on the plate right now and nothing ready to say it's finished. Focus on the two at hand. If you buy it try flipping it. Just my $.02.
  17. Brett
    A very important part is the deck lid, it has been my experience as of late that mid to late 30s Ford deck lids are golden.
    Patc panels are available for that as well as a floor etc. Doors may be hard to come by and the front sheet metal original may not be easy either. You can get the front clip in gl*** if push comes to shove, just get paint on it and don't tell anyone.
    Worth, 600-1500 is what it would probably go for around here depending on how complete it is.
  18. brett4christ
    brett4christ
    JJ, yes, I know YOUR opinion! :D Check your PM's!
    PnB, I'm pretty sure the deck lid is sitting under the carport, near the plastic Willys in the background. I don't think I'd touch it if it didn't have the lid....unless it was less than 4 Benjamins!
  19. oldolds
    oldolds
    You can't give too much to buy that car if you plan to fix it. The floor pan and ***orted patch panels will run you in excess of $1000, unless you are skilled at sheet metal fabrication. Then it will take you 1000 hrs. of work.
    You will have to buy every little thing to put it together. every nut, bole, bracket. Now I understand we are going to change it a bit when we hot rod it, but the more that you have to start with the better.
    The car is only worth about 1/2 of what you can sell the best parts for. Remember you have to haull all of it away and haul the junk to the recycler. Now the good part is that you can sell any part of that car that isn't rusted thru.
  20. brett4christ
    brett4christ
    Oldolds,
    Yep, I understand everythning you're saying. But....if I picked up a sedan parts car, I could EASILY us it to build this coupe (or at least get it well on it's way)!
    I just hate to see old iron not get a hot-rodding chance!
  21. parts cars are fine, but this car plus a parts car equals save your money and buy a better car. id give 1500 for it,
  22. -Brent-
    -Brent-
    HAHAHA! Who hacked your account and typed the quote above? It can't be the guy with a 32, 33/34, 35, 54.... :D
  23. HOTRODPRIMER
    HOTRODPRIMER
    Brett,You are basically buying a parts car ,,you really don't want to pay more than you have to,,if he has a ***le and frame maybe 900 - 1400.
    Do you really want another project? HRP
  24. FalconMan
    FalconMan
    from Minnesota
    If it has a decent deck lid and rear fenders, those alone are worth about $1500 on a bad day.
    I'd give $2500 for it if I were looking for one.
  25. It's a '36, I would say the going price around here (cal) is about $3500-$4000 (with ***le) on what you said. BUT make sure the rear fenders are for a coupe, the high ticket items you need to make sure are there are rear fenders, trunk lid and grill.
  26. alchemy
    alchemy
    I'm no 36 afficianado, but I hear that 36 coupe rear fenders are worth big bucks. BUT (!) you have to be sure you are buying coupe fenders, and not 35 fenders. Do you know the difference?
  27. brett4christ
    brett4christ
    If it's a 36, there's no grille for it. I'm pretty sure she has one for a 35, but it may not be for sale.
    How am I to be SURE they are coupe fenders?
  28. 36cab
    36cab
  29. The differences are slight. The '36 has a crown down the center and the sedan '36 fenders are shorter from the crown to the edge where it bolts to the body. Also the "X" on the firewall makes it a '36.
  30. brett4christ
    brett4christ
    1OT
    I won't have two different fenders to compare. Do you know the measurement from crown/peak to mounting flange on a coupe fender?
