Technical Here's a wierd wired one -
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, May 28, 2018.
  1. I've only got a few mins into this one but it's definitely different.
    I haven't got to check the thing out thoroughly but this is what happens.
    1. There is power coming into the ignition switch.
    2. There's no power coming out of the ignition switch.
    3. Plugged in a new ignition switch and the same problem.
    Ok
    WTF???
    Check a couple other things with the new switch
    Key off - has power into switch
    Key On - kills power into switch as far up the harness as I can reach at the moment.
    This one should be fun.
    Was supposed to be quicky " can you change my ignition switch? "
    I tried to get the guy on the road this morning so he could go have some fun.
    Not gonna happen cuz I'm almost late for a cookout.
    pat59 likes this.
  2. Blues4U
    Blues4U
    from So Cal
    Sounds like a restriction in the supply to the key switch. Voltage drops because of the resistance. The resistance will cause heat. Turn on the switch and turn on some accessories and search for the hot spot.
    porknbeaner likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Did you do a continuity test to only the switch to see if it's only there? Are there relay's involved with this vehicle? Edit - more things > Is it a bulk plug or individual wires placed individually? (I do not know if this car ran before or is freshly wired) I've seen bulk plugs where the wire has been placed into the wrong hole.
    OahuEli likes this.
  4. RMR&C
    RMR&C
    from NW Montana
    Aftermarket harness or OE? New problem or it never worked?
  5. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Test the switch on the bench if you can, isolate if it's a wiring or switch issue.
    Russ B likes this.
  6. Its OEM harness,
    Supposedly it Worked last year, which makes this is new problem. Newly Purchased with this problem. So all history is Deemed unreliable until I prove otherwise.
    I will bench test the switch just to cross it off without ***umptions but there are 2 different switches that didn't change the same issue.
    My plan is to start with the battery- prove it worthy and work my way out from there with a volt meter
    fauj, upspirate, RMR&C and 4 others like this.
  7. rfraze
    rfraze
    He brought it to the right guy. Happy Memorial Day.
  8. klawockvet
    klawockvet
    Not sure if I understand correctly but if the power into the switch goes out when the key is turned to on but comes back when the key is off I would suspect a circuit breaker in the incoming line. Or, if the voltage at the switch is extremely low, it wouldn't take much of a load to draw it down to zero. In either case I would look for a dead short in one of the circuits coming out of the switch. I have done this by removing the plug and isolating the incoming power wire. Hook a test light to that incoming hot lead along with a jumper wire. Then go to each of the other wires in the harness and see which one causes the power to drop. If its a factory harness you should be able to find the circuit via Google by the color of the wire.
    scrap metal 48 likes this.
  9. nrgwizard
    nrgwizard
    from Minn. uSA
    Hmmm;
    I'm guessing here:
    Could be a bad batch of switches, but that is somewhat unlikely.
    It sounds like barely enough voltage to the switch to register, but no amps through.
    Sounds like a damaged wire upstream of the switch(most of wires broken, but 1 wire in strand to allow voltage/ no amps through), or hidden corrosion downstream(anything from corrosion at connection to corrosion *inside* of wire to burned wire inside of insulation that doesn't show much outside). Problems I've run into chasing similar symptoms in the buses.
    What happens if you jumper off the sw output to some load that (you know has a good ground) you could measure, to see if the upstream side is ok? Mouse-chewed wiring somewhere? This'll be interesting...
    Marcus...
  10. sunbeam
    sunbeam
    Jumper 12v to the power side if stuff works it's narrowed down. If it's in the power wire and there is a gl*** fuse I'd check the fuse contacts first.
  11. Engine man
    Engine man
    from Wisconsin
    Could be fun. Would seem to be a problem between the battery and the ignition switch unless it's losing the ground to your test equipment. First thing I would do is connect a wire from the battery to the ignition switch. I have a long 12 gauge wire with a 30 amp fuse, a large clap to connect to the battery on one end and a variety of terminals that can be plugged onto the other end. It can be a connection on the starter or starter solenoid depending on the system.
    Mr48chev likes this.
  12. BJR
    BJR
    Have you checked the battery cables? I have seen a car with 12 volt showing all over the place, but when you try to blow the horn, turn on the lights, or hit the starter it goes to 0 volts. Turns out to be bad connection at battery or a bad connection at the starter. Even if they look good take them apart and clean them. Check the ground cable to frame connection also.
    upspirate, dogwalkin, egads and 3 others like this.
  13. greybeard360
    greybeard360
    Since you say it is OEM wiring... What are we working on?
  14. Engine man
    Engine man
    from Wisconsin
    The bolt on style of battery cable ends were notorious for this.
    belair likes this.
  15. RICH B
    RICH B
    Used to wiggle the firewall plug on my Chevelle to fix that problem. Finally wired the power lead around the plug.
    So I'm guessing a corroded or maybe "load damaged" connection.
    RMR&C, tb33anda3rd and Johnny Gee like this.
  16. Dennis D
    Dennis D
    Gl*** fuses? Had one that was intermittent between the cap and the element, but I doubt the main feed would be fused from the factory. Next place I would go is to the bulkhead connector at the firewall if it is a GM product. D
    Rich beat me to it!
  17. F-ONE
    F-ONE
    from Alabama
    You've got that right!
  18. scrap metal 48
    scrap metal 48
    He must be at the cook out having a hamburger and a beer...
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is it a 60's Buick? They had ignition switch issue's up the *** and would do the same thing. They also were non interchange able with other GM switch's unless you wired it wire by wire minus the multi plug.
  20. tb33anda3rd
    tb33anda3rd
    i am guessing bad /loose connection. firewall plug or failing fusible link.
  21. I’ll dig into it more tomorrow
  22. Battery voltage was only 11+ volts after full charge.
    Hit it with a load and it fell to zero. Didn't think the needle on my guage could move that fast . Lol.
    olscrounger likes this.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    So much for the "customer is always right". :)
  24. We will see soon see if there are other issues as well. But there's no sense in getting ahead of a bad battery.
    What's funny,, really funny,, the seller made it a point to tell the buyer "the battery is good, fully charged" and of all the non relevant and completely unreliable information the new owner tryed to impart upon me, 3-4 times about the battery being good. SMH.
    I told him my plan about starting at the battery and proving it worthy, he thought that would be silly since it's "Good"." The guy I bought it from charged it and it would go dead from a short in the ignition switch, must be a short someplace else" I called and told him "yep, the first short I found is something inside the battery, now you could take it back to the guy who couldn't fix it but that would be really silly." - you just fix it and I'll shut up.
    Yeahhh!
    loudbang and Johnny Gee like this.
  25. Engine man
    Engine man
    from Wisconsin
    Yes, you can't run a battery dead very many times before killing it. Overcharging it is just as bad.
  26. If it the OEM harness it could be the plug in the firewall that is your problem. On my '65 for example I had power every where till I tried to start it then bababam. Nuthin. Switch tested out just fine, and what I ended up doing was byp***ing the plug in the firewall for power to the switch then everything was groovy. Near as I could figure that firewall plug was too old and corroded to let enough amperage to p***.
  27. Chappy444
    Chappy444
    Make sure that there is not a bad kink in the positive battery cable restricting the flow of electricities. My neighbors cousin's foot doctor had this exact same problem in his Pontiac Aztec. He had to take the whole cable out of the car and lay it on the driveway in the sun to warm it up so it would get soft enough that he could straighten it out. Once he got that nasty kink out he had great flow and pressure of his electricities. He said his tailgate opened faster and everything... so you should check that.
    prewarcars4me, SS327, blowby and 5 others like this.
  28. Blues4U
    Blues4U
    from So Cal
    Yep, starting at the battery first was a smart move, always do the basics first. Go from easy to hard, do the easy stuff first. If it doesn't have a good battery there's no sense going any further until that's remedied.
  29. tb33anda3rd
    tb33anda3rd
    i have had customers tell me they fully charged a battery and it was still dead "i had it on the charger the whole time i was at lunch"
    pat59 and Hnstray like this.
  30. 1 trust but verify.
    So far in all of my colorful travels across the world, seeing a battery with that immediate and m***ive of a voltage drop to zero was a first for me.
    New Battery is on the way.
    upspirate, pat59 and Blues4U like this.
