Projects Hesitation off idle
Discussion in 'The Hokey Ass Message Board' started by Olds Guy, Dec 30, 2010.
  1. Olds Guy
    Olds Guy
    from OK
    I have a 60 olds with 371 and 2gc carb that I cannot get all the hesitation out of. Carb was rebuilt but still has a problem. can anyone help??
  2. Novadude55
    Novadude55
    from CA
    first, is your vacuum advance hooked up? is it working?
    second, is your accelerator pump squirting gas when you work the throttle?
  3. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    Vacuum leak?
    how does she idle?
    is it hesitation off idle only under load?
    do you have backfire with the hesitation?
  4. scrubba
    scrubba
    I' m with Guns wanted here . Generally, I have found this to be within the accererator pump . Rochesters were bad about this . I guess the next thing would be to see how much vacum is pulling too. If you don't have a good pull,, check the fittings and see if the vacum port on the distributor will pull with a hand held vacum pump. scrubba
  5. Nortin
    Nortin
    from Canada
    Is it a points and condensor distributor? If it is throw in a new set of points and condensor. check the dwell angle(point gap). Carbs can get blamed when they are not the guilty party. I'm not too familiar with the olds manifold( or plain dont remember) but does it have a heat passage across the dome like the small block chev and is that choked with carbon? ,,worth checking. Ya can't beat having a vacuum guage on a running engine for verifying or eliminating problems.
  6. Deuces
    Deuces
    Ditto on the vacuum gauge!! :)
  7. burnout2614
    burnout2614
    Along with checking for vac leaks look for stuck accel pump check ball (if no spray) peace
  8. GOATROPER02
    GOATROPER02
    from OHIO
    If pump is working OK try bumping up the timing from the std 5 degree mark to 8-10 degrees
    Youll still only have around 36 total
    Ive seen this fix many an Olds stumble when engine vacum is on the lower side,or vac advance is lazy
    Or some times they just like it that way!!
    Tony
  9. Olds Guy
    Olds Guy
    from OK
    I have replaced vacuum advance but may need to check again to see if it still works. The accelerator pump squirts but it seems to do it a little late.
  10. Olds Guy
    Olds Guy
    from OK
    It idles smooth and the only time it really hesitates is when I stop at a stop sign or light and sometimes when I turn a corner in town. I have had the carb apart and it looks like the accelerator pump housing has some wear on one side. Can you put a sleeve in it for an even wear surface ??
  11. DadsDodge
    DadsDodge
    If this happens when on the brakes or around corners, I would check the float level.
    Too low= starvation Too high gives fuel slosh and flooding with G forces
  12. davidwilson
    davidwilson
    from Tennessee
