Hey All New Mopar Guy...
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Broncoholic, May 11, 2009.
  1. Broncoholic
    Broncoholic
    from Michigan
    Just got my 1st Mopar. 1963 FC170
    !st real Mopar had a few CJ5's they don't count.
    I need a kick down ***bly. to drive it. How do you tell if it is a 904 or a 727? or a 360 for that matter?
  2. moparforlife
    moparforlife
    from Rolla, MO
    Welcome to the HAMB. To tell if your trans is a 904 or 727, look at the pan. If there is a bulge on the p***enger side it is a 727, if the pan is relatively square then it is a 904. To tell if your motor is a 360, you will have to look at the casting numbers on the side of the block. Good luck on the Charger.
  3. PlyPals
    PlyPals
    Altough I have an older MoPar,
    Welcome aboard from Belgium!
  4. Broncoholic
    Broncoholic
    from Michigan
    The head has a 36 on the rear by the last exhaust. I have to jack it up to get a look at the other casting #s. The pan has a small hump on the trans pan & it is not square. Is it a 727 I hope?
    What side are they at Under the starter?
  5. Austin296
    Austin296
    welcome from texas
